Books Covering Making Fireplace Mantels - Router Forums
post #1 of 9 (permalink) Old 06-26-2013, 12:04 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Books Covering Making Fireplace Mantels
I see there are quite a few books on Amazon on the subject. Conflicting customer opinions. I was wondering if any members with experience could suggest any worthwhile books to get hold of that would give me all the information needed to make my own wooden fireplace mantel?
Thanks.
Gaia is offline
post #2 of 9 (permalink) Old 06-26-2013, 02:43 PM
MAFoElffen's Avatar
Peter-
Never seen a book on them, but was a finish carpenter before master carpenter... That's when I first learned about making mantles.
First decide how ornate and ornmental you want to get, whether a paintout or woodgrain, etc.
Basic parts of a fireplace mantel from bottom to top-
legs (sometimes with plinths), header, mantel shelf, over mantel, crown.
In what makes a mantel, in order of importance through pieces being optional-
mantel shelf, header, legs, leg plinths, over mantel with crown.
The legs are a 3 piece wrap for each leg, with the sides nailed to the back of the front of the legs. The outside going to the wall the inside going to the fireplace. The front piece could be plain, panels, fluted, etc.
The header is just 2 pieces, with the front going between the legs, the bottom nail to the back of the header bottom and goes the the face of the fireplace. The header could be plain, panled, fluted, etc.
The mantle shelf nails to the of of the legs and the top of the header. I use mixes of trim and crown moulding to make it more ornate and add depth. I route or add trim to the edge of the shelf based on the design.
I add nailers to the masonry and wall, to make it easy and solid to attach to.
Above the shelve is even more optional and based on the design... and over mantle and crown... adding more ornament.
Sometimes, I tied the legs and/or over mantel into custom shelves. Usually shelves beside the legs. Sometimes shelves in the over mantel. One job, they wanted a flat screen in the over mantel.
Fitting and construction tips:.
Measure it out in detail. Check level and straightness of the fireplace and wall. Especially in a remodel, it's usually the worst wall in the house for level and straightness. The masonry is rarely even with the wall. It's a creative challenge. Think 3 dimensional.
How I make up for that is taking the unstraightness to the back wall and measure that to where the fron of the mantle shelf "will be", compensatinge for thosee curves to bring the front face of that shelf even (across left to right) with the front of the fireplace.
That will then guide you with the measurements of the top sides of you legs. Take a level and go down from there. That will show you the tapers for your legs.
Cut out the mantel shelf and legs sides within 1/8 to 1/4 over... set in place and mark with your pencil flat against the wall or fireplace... That will give you the contour. The cut doesn't have to be exact... As i use trim moulding or other moulding to bend right to the edge and blend it in.
I think I have some pictures around here somewhere of the last one I did. It was a basic hardwood mantel with some trim and crown to match the rest of the house. Over what was a concrete faux stone fireplace... new black with green granite hearth and face, with a new fireplace insert. ... With hardwood side cabinet shelves. I'll try to find it to post.
MAFoElffen is offline
post #3 of 9 (permalink) Old 06-26-2013, 09:07 PM
Hi Peter, I used to build them and I can't really recommend a book. I haven't seen one I would say is good. Some of these are not hard to make. Fireplace Surrounds | Fire Place Mantel | UltimateCarver.com Here's some more- https://www.google.ca/search?q=firep...w=1280&bih=861
And here is a lot more-http://www.houzz.com/fireplace-mantel-plans
The one I built for myself has legs so it is self supporting but is very front heavy and wanted to fall forward. I just used a couple of home made clips like these to keep it against the brickwork. Z-Clips - Lee Valley Tools If I wanted I could just lift it up and take it down if needed. Oh yeah, I just made sockets on the bottom of the mantel for the legs to fit into. They separate too. If I can be of more help just ask (PM me, i.e.) and I'll do what I can.
post #4 of 9 (permalink) Old 06-26-2013, 09:53 PM
JOAT's Avatar
First Name: Theo
Many years ago when the ex was still not the ex, I got a zero clearance fireplace, installed it, built a surround with those glue on brick things, then made a mantel out of a nice piece of 2X12 pine. And it looks good. "I" wanted a wood stove, but, nooo, "she" had to have a fireplace. Miserable things for heating, but look great.
JOAT is offline
post #5 of 9 (permalink) Old 06-26-2013, 11:32 PM
MAFoElffen's Avatar
Found those pictures of the last one I made (attached).
post #6 of 9 (permalink) Old 06-27-2013, 09:28 AM
Here is the one I built for my house. Not a good picture, my renter took it for me with a cell phone for me.
Peter, figure out a style that will fit with its surroundings and then look for something that fits with your skills and available tools and the amount of effort you want to put into it. I made mine out of western white birch which I logged myself and had a neighbor saw up for me so making all the moldings was very labour intensive. Depending on what wood you use, you might be able to purchase some of the moldings to make it quicker and easier to build.
Name:	Mantle cell phone photo.jpg
post #7 of 9 (permalink) Old 06-29-2013, 01:19 AM Thread Starter
Gaia's Avatar
First Name: Peter
Originally Posted by MAFoElffen View Post
Peter-
Cheers for the info.
Gaia is offline
post #8 of 9 (permalink) Old 06-29-2013, 01:20 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks.
Gaia is offline
post #9 of 9 (permalink) Old 07-04-2013, 08:47 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Originally Posted by JOAT View Post
Many years ago when the ex was still not the ex, ...
Hi, JOAT.
Very nice description about her.
We, woodworkers are everywhere!!!
papasombre is offline
Dirty Little Secrets with Sign Making... newmexico Sign Making 45 06-18-2016 02:59 PM
Info, Books and Plans On Making Gates Gaia Project Plans and How To 0 02-28-2012 04:59 AM
Woodworking Books and DVD USA/Canada tigerhellmaker Starting Off 0 01-26-2010 02:44 PM
