Big Wet/Dry VAC Drywall filters? - Router Forums
post #1 of 15 (permalink) Old 07-02-2013, 10:04 AM Thread Starter
MAFoElffen's Avatar
Default Big Wet/Dry VAC Drywall filters?
You guys know I have that monster converted commercial truckmount wet/dry vac... Even though I have the DC up, I'm still using it to clean up my shop. Even though I have it on a separator, I have a problem with fines blowing out it...
I've been trying to find drywall filters big enough to fit it. The ones I find in Lowes and Home Depot are the small ones for "Shop Vac" Wet/Dry Vacuums, which are a lot smaller that this is...
Does anyone know of someone that sells larger ones and for what make/model application?
MAFoElffen is offline
post #2 of 15 (permalink) Old 07-02-2013, 10:42 PM Thread Starter
MAFoElffen's Avatar
Never mind.
First I was thinking of buying a big vacuum bag. But really not the right thing.
Looked at cut-to-fit 3 layer vacuum filer material. 24" x 24" is $20.
post #3 of 15 (permalink) Old 07-02-2013, 10:52 PM
Either that or pre-fill your vac with some water and use the water to filter the fines out like a pre 1955 automotive air filter. The water would get pretty yucky.
post #4 of 15 (permalink) Old 07-02-2013, 11:21 PM
kp91's Avatar
First Name: Doug
Sears has 20 gallon shop vac bags for drywall dust. They work great for MDF dust too.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 15 (permalink) Old 07-03-2013, 11:13 AM Thread Starter
MAFoElffen's Avatar
Here's a picture from my uploads:
Inside , under the motor, it has a cage with a 4.5" ball, that shuts off the flow it full of water. Around that is a plastic cone. (edit- not really a cone. more like a tapered tube)
The sear 20 gallon shop vac drywall filter looks like this:
That won't work... Unless maybe I cut the bag up into a circle and used it as filter paper like a standard drywall filter, like the next photo...
I was thinking something along the lines of these:
The plastic cone on mine could hold something like those in place if I could find or make something big enough.
post #6 of 15 (permalink) Old 07-03-2013, 12:38 PM Thread Starter
MAFoElffen's Avatar
Here's a quick pic of the underbelly. That's a course bag on there. I suppose just to keep pieces out of the 2-stage impellers.
Charles- I'm embarrassed that I remember when those oil-bath air-filters were common... But where would I put an oil bath where bigger and mass amounts of dust wouldn't muck it up? On cars, they were meant for "just" fines, with not much of an occurrence of anything else // unless a mouse crawled in there to make a nest...
post #7 of 15 (permalink) Old 07-03-2013, 05:30 PM
Yeah, dumb idea. You are thinking about filtering everything that goes into the drum. How about just attaching a filter to the exhaust, possibly on the outside of the drum? That would be much smaller and, depending on what you come up with, could be easier to clean.
post #8 of 15 (permalink) Old 07-03-2013, 05:31 PM
TwoSkies57's Avatar
Hey Mike... have you checked to see what Grainger might offer?
Skipper the Penguin
TwoSkies57 is offline
post #9 of 15 (permalink) Old 07-03-2013, 06:32 PM
First Name: Den
you might try
PARKER Filter Bag, Polyester, 1Micron, PK10 at Grainger
you would have to build a frame inside to hold the bag open
search Grainger for bag filters
NotToDay is offline
post #10 of 15 (permalink) Old 07-04-2013, 02:14 AM
First Name: Dick
Mike I just checked McMaster Carr. I think they may have exactly what you need, even though they are kinda pricy on stuff.
Where there's a Willis there's a way!
Willway is offline
Dust Collector WD1450 Wet/Dry Vac blboyd Ridgid Manuals 0 03-10-2011 08:19 AM
Dust Collector WD06700/WD09700 Wet/Dry Vac blboyd Ridgid Manuals 0 03-10-2011 08:19 AM
Shop Vac Water Filter Soapdish Tools and Woodworking 15 01-25-2010 12:22 PM
