In Regard To That Trash Can Lid... - Router Forums
post #1 of 26 (permalink) Old 07-02-2013, 11:07 AM Thread Starter
First Name: Jerry
Default In Regard To That Trash Can Lid...
This thread is just a heads up to the members that use the trash can and special lid for the separator in their dust collection system.
Lately I noticed that the suction on the system was getting weaker and that chips were accumulating behind the DC so it was time to have a look and see what was going on. What I found was that the chips and dust had begun to build up under the the edge of the lid where it seals to the top of the trash can. After throughly cleaning the channel out that fits around the edge of the lid and fits over the rim the trash can to form a seal, everything seems to have returned to normal. The suction seems to be much stonger but I did the clean up this morning and have not run the DC long enough to be certain that the seal is doing it's job. Before this problem was fixed I notices that the jointer was spitting chips out of the top and when I checked the hose it was not pulling the chips out of the jointer. I'm sure glad that I found the problem. I'm just saying that if you are one of those people that use the trash can with thw special lid, keep an eye on the seal to keep things working for you. Oh, just in case you're wondering, the lid on my system is held down with bungy cords.
Jerry
Jerry Bowen is offline
post #2 of 26 (permalink) Old 07-03-2013, 09:52 AM
I found my trash can separators leaked and reduced suction from the start and went to ULead and bought a 30 gallon fiber drum with steel top and a clamping rim that seals it tight. No more leaks, lots of suction. Thinking about how to put a plexiglass peep hole in it so I don't have to open it to see how full it is. Maybe a hole in the top with the plexi bolted in place with a gasket and lots of calk to seal it tight.
post #3 of 26 (permalink) Old 07-03-2013, 12:48 PM
MAFoElffen's Avatar
Holy Cow Batman!!! I've been wondering the how-to of that... and of course over thinking it. That sounds like some real simple solutions that I want to try out for mine! Thanks Tom.
What I have been doing is either check... or when I start seeing shavings in the bag, I know I was too late. LOL.
MAFoElffen is offline
post #4 of 26 (permalink) Old 07-03-2013, 02:14 PM
MT Stringer's Avatar
I don't need a stinking peep hole! :-)
Just kidding.
MT Stringer is online now
post #5 of 26 (permalink) Old 07-03-2013, 06:12 PM
TinyTiger's Avatar
First Name: Russ
Great tip Jerry. Thanks!
TinyTiger is offline
post #6 of 26 (permalink) Old 07-03-2013, 06:46 PM
Question Question, Mike
Just kidding.
Is your lower baffle the same diameter as the inside of the drum, or slightly smaller?
Sydney, Australia
jw2170 is offline
post #7 of 26 (permalink) Old 07-03-2013, 08:24 PM
James, part of the baffle (120 deg.) is the width of the drum and the rest (240 deg) is a little smaller. For a better description, check out Phil's website.
Phil Thien's Cyclone Separator Lid
post #8 of 26 (permalink) Old 07-03-2013, 09:47 PM
roofner's Avatar
First Name: Gary
Desertrat I don't know the what the term Ulead is? I would like a source for a fiber drum.
roofner is offline
post #9 of 26 (permalink) Old 07-03-2013, 11:01 PM
Here ya go, bud.
ULINE
I think that is what he meant. I have ordered stuff from the, before.
post #10 of 26 (permalink) Old 07-08-2013, 06:35 AM
Default Uline, not ulead
Here ya go, bud.
ULINE
Uline is what I meant. 70 year old memory cells. LOL
Lucky me... a new cyclone! Julie Tools and Woodworking 27 02-05-2013 04:16 AM
45 degree cuts on box lid Marco The Finishing Touch 5 07-02-2011 12:17 PM
help with loose box lid awoodnut Table-mounted Routing 5 01-03-2010 10:38 PM
Trash Can RStorment Show N' Tell 10 10-18-2006 03:53 PM
Lid Lip RichB New Member Introductions 6 01-03-2006 06:08 PM
