Wondering A Lock Miter Bit - Router Forums
post #1 of 36 (permalink) Old 04-09-2014, 08:33 PM Thread Starter
First Name: Jerry
Default Wondering A Lock Miter Bit
it has been suggested to me to acquire a lock miter bit for a certain project as well as other projedts in my woodworking shop.
I read on the web how difficult it is to set these bits up unless the thickness of the workpiece complies almost perfectly to a set up blocks.
I am wondering if members that are familiar with this router bit feel like the bit is really so difficult to set up that I should forget it or not, I think that the challenge of setting it up is one that I want to try and probably will, but I would appreciate some input on the subject.
Jerry
Jerry Bowen is offline
post #2 of 36 (permalink) Old 04-09-2014, 08:57 PM
I know Harry has posted before on how he sets them up. If you search Google for CMT's downloadable catalog it has instructions in it for how to set one up without the blocks. It's just a matter of getting it close by measuring and then tweaking the adjustments on scrap the same size as what you want to rout until you get it right.
post #3 of 36 (permalink) Old 04-09-2014, 09:15 PM Thread Starter
First Name: Jerry
Makes perfect sense to me and is why I feel that I'm willing to give it a try. The height adjustment on my rounter in the Mast R lift is so precise that it just seems to me that that one could do exactly what you describe Charles.
Jerry
post #4 of 36 (permalink) Old 04-09-2014, 09:58 PM
GulfcoastGuy's Avatar
First Name: Patrick
I right there with you, Jerry. I've got a project in mind that would be a prime candidate for one but the setup fears have kept me from going for it. I found this setup tutorial that seems about as straight forward as I think it could get.
Setting Up a Locking Miter Bit
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #5 of 36 (permalink) Old 04-10-2014, 06:49 AM
PawPawRay's Avatar
First Name: Ray
This months Shopnote Mag has step by step instructions for setting up this bit.
PawPawRay is offline
post #6 of 36 (permalink) Old 04-10-2014, 08:01 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
First of all Jerry there are at least three sizes of lock mitre bits covering; 12-16mm,
14-19mm and 19-28mm wood thicknesses. I sit the wood at the side of the bit, where it would be placed to commence routing, I then "squint" along the table so that I can set the height of the bit and the position of the fence. These settings are of course approximate and it then takes several test cuts on scrap wood in order to achieve a perfect result. After completing a perfect project I then make a test piece for quick set-up next time that I use the same thickness wood and with a thickness planer it is easy to duplicate the thickness. Even using the test piece very slight adjustments may still be necessary.
Like most things, practice makes perfect so, after your first perfect box, make several more and the process will no longer be a worry.
Harry
harrysin is offline
post #7 of 36 (permalink) Old 04-10-2014, 03:30 PM
TwoSkies57's Avatar
Take a look at this Jerry..
Infinity Cutting Tools Lock Miter setup guage.
2-Pc. Lock Miter Master Jig Set - For 3/8 - 1-1/8 Stock-Carbide Router Bits | Router Bit Sets | Shaper Cutters | Saw Blades | Planer Knives | Jointer Knives | Infinity Cutting Tools
A couple of Youtube video's;
Infinity Cutting Tools Lock Miter Master Jig - YouTube
PDF instructions on setup and use...
http://www.infinitytools.com/PDF/Loc...r%20Manual.pdf
Skipper the Penguin
TwoSkies57 is offline
post #8 of 36 (permalink) Old 04-10-2014, 03:41 PM
BCK
First Name: BC
been thinking on one of these myself, but setup was an issue in my mind...thanks to all who posted and explained etc...as this did help make my mind up to get one and give it a shot...thx
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #9 of 36 (permalink) Old 04-11-2014, 07:19 AM
CharleyL's Avatar
First Name: Charley
The Lock Miter Master setup jigs from Infinity Tools make setting up these bits very easy and they are well worth the cost. To use them you simply determine the exact center of your stock, place the jig on the lock miter bit (it's held in place by internal magnets), and then adjust the bit height until the line on the jig matches the center of your stock. You then set the position of your fence by using the top line on the lock miter jig to the center line of a piece of your stock held against the fence. When the bit-to-stock positioning is correct you will get perfect lock miter joints. The instructions for the Lock Miter Master jigs will also explain how to make offset joints and other cool tricks that you can do with lock miter bits and the Lock Miter Master setup jigs.
Charley
Central North Carolina
CharleyL is online now
post #10 of 36 (permalink) Old 04-11-2014, 11:10 AM Thread Starter
First Name: Jerry
Harry,
In this rare instance we both spot on the same page. You have described exactly what I envisioned having to do to use the bit. Saving the scrap set up and marking is is just what I described to another member before I read your post. Thanks for you confirmation of my thoughts on the matter.
Jerry
lock miter bit stripper Router Bits - Types and Usage 6 11-30-2012 01:51 PM
30 degree miter lock bit available? Jlaw Router Bits - Types and Usage 17 04-12-2012 09:16 PM
45 Degree Lock Miter bit mjeisenbaugh Router Bits - Types and Usage 9 02-02-2011 11:53 AM
Lock miter bit for 3/8' pine lpret Router Bits - Types and Usage 8 04-28-2010 09:31 AM
using a 45 Lock Miter Bit allthunbs Table-mounted Routing 3 07-07-2008 04:04 PM
