uneven legs - Router Forums
post #1 of 19 (permalink) Old 04-19-2014, 07:55 AM Thread Starter
First Name: rich
Default uneven legs
Hi Guys, this is really a problem
I'm making living room tables for son and his spouse.
Since I don't have a lathe, I got some pretty nice ash legs online.
I was extremely careful about cutting the lumber for the initial skeleton that holds the legs equal.
I was building it on my cast iron table saw because I know it's true.
After I stained it, it began to wobble, seems like one of the legs is approx 1/16 shorter.
Any suggestions on how to square the legs??
Last thing I want to do is take it apart or start sawing.
Thanks,
Rich
r6264 is offline
post #2 of 19 (permalink) Old 04-19-2014, 08:08 AM
TwoSkies57's Avatar
Hey Rich, welcome to the community...
Since you obviously have the skills to build the table/chairs you'll have no problem
adapting this video to your needs. Much easier than trying to explain it to ya. I used
this method recently on a rocking chair build and it worked exceptionally well.
The "sandpaper trick" - YouTube
Skipper the Penguin
TwoSkies57 is offline
post #3 of 19 (permalink) Old 04-19-2014, 08:13 AM
JOAT's Avatar
First Name: Theo
No problem. I carry a cane now, and it does a great job of preventing wobble.
Now you see why I make things with three legs, instead of four.
You can always go with something like these, that's what I would do; either that for a matchbook under the odd leg.
Rockler - Search Results for leveler
JOAT is offline
post #4 of 19 (permalink) Old 04-19-2014, 10:06 AM
Gaffboat's Avatar
First Name: Oliver
That's a very nifty trick, Bill. A quick and easy solution to what could be a frustrating challenge. Thanks for sharing it.
Gaffboat is offline
post #5 of 19 (permalink) Old 04-19-2014, 10:18 AM
Semipro's Avatar
First Name: John_*
Bill
Not sure I can explain to your understanding
First place table on level area then shim the short leg,now take a small piece say a 1/4" thick hard board lay it on the level surface and mark all four legs using the top of the 1/4" board then cut them at the line
( you should not be cutting as much off short leg) hope you understand
Semipro is online now
post #6 of 19 (permalink) Old 04-19-2014, 10:43 AM
Nickp's Avatar
First Name: Nick
Thanks,
Rich
Would a small stick-on felt pad do the trick...? Maybe a thicker one for the short leg and thinner ones for the other legs...?
Nick
Nickp is online now
post #7 of 19 (permalink) Old 04-19-2014, 11:28 AM
brille's Avatar
Country: Germany
First Name: Uwe
Hi,
here are two other methods for leveling chairs:
https://www.youtube.com/watch?v=vq94qo7WbEw
https://www.youtube.com/watch?v=1ScTjOX8CLI
tht
Uwe
brille is offline
post #8 of 19 (permalink) Old 04-19-2014, 11:50 AM
MAFoElffen's Avatar
Hate when that happens (LOL)... but it happens.
The reason it happened? Because before staining and finishing, there was unrelieved tension in the wood. That could have been just normal happenings when you take two pieces of wood and align the face surfaces during a glueup... Then when it gets wet, the tension tries to relieve itself... It probably took a slight twist when it did that. When you are in the middle of that, you can pre-relieve some of that by wiping it down with mineral spirts or alcohol, which alos helps clean the pores. Then adjust for it.
Now that it is relieved, It should be fine from now on. Taking it apart to redo it... Might introduce more tension back into it... Then you are going to be going through that again.
The method presented is good. Takes into affect that the workpiece is going to be in the position it is going to be used. There's some other variations of that... but that works. Another is to ensure the surface you measure from is level, then shim the workpiece so the top surface is level. That will keep help prevent that DIY spoof commercial where the guy leveled his own table and the glass slides off it... from happening.
MAFoElffen is offline
post #9 of 19 (permalink) Old 04-19-2014, 12:23 PM
CharleyL's Avatar
First Name: Charley
For that slight of an adjustment I would just attach a piece of 80 grit sandpaper on the top of your table saw and slide one of the longer legs back and forth across it until all 4 legs sit on your flat surface without wobbling. You will only need to remove about half of the gap that you presently see under the short leg when the table is sitting on the other three legs.
Charley
Central North Carolina
CharleyL is offline
post #10 of 19 (permalink) Old 04-19-2014, 01:09 PM
MAFoElffen's Avatar
Originally Posted by charleyl View Post
for that slight of an adjustment i would just attach a piece of 80 grit sandpaper on the top of your table saw and slide one of the longer legs back and forth across it until all 4 legs sit on your flat surface without wobbling. You will only need to remove about half of the gap that you presently see under the short leg when the table is sitting on the other three legs.
Charley
+1
But that assumes "the table" would sit completely on the OP's TS top... It would fit on my panel saw (32"x72"), but not on my jobsite saw's top.
Question About Table Legs? Jerry Bowen Lobby 12 03-03-2014 11:28 AM
attach a shelf to table legs sam2007 Project Plans and How To 4 05-27-2011 11:55 PM
table legs dribron General Routing 1 08-05-2010 10:59 PM
Folding table legs Qstick Tools and Woodworking 13 02-24-2007 01:05 AM
queen anne legs rdinkins Jigs and Fixtures 14 11-04-2006 02:38 AM
