DeWalt 7770 restoration - Router Forums
post #1 of 6 (permalink) Old 04-24-2014, 02:03 PM Thread Starter
Country: South Africa
First Name: Johann
Send a message via Skype™ to johannmendelsohn
Default DeWalt 7770 restoration
I have bought a DeWalt 7770 radial arm saw very cheap
but found it sticky and inaccurate and going out of plumb every
so often. I decided to strip it down to the bone and found
it clogged up with old oil and saw dust goo! Little bit of surface
rust on spring pins. It looks like a thorough cleaning and
polishing of contact surfaces might just do the trick!
Has anyone else done the same?
Regards from South Africa
johannmendelsohn is offline
post #2 of 6 (permalink) Old 04-25-2014, 06:03 AM
First Name: Richard
Send a message via Skype™ to rwbaker
In situations such as this I have found Kerosene and spray cans of brake cleaner and engine starting fluid (ether) to be invaluable. Not environmentally friendly, they can soak through the skin, very flammable and some brands can remove the paint, but they do work in the instance you describe.
I do not envy the job ahead but your results should be worth it. - Baker
rwbaker is offline
post #3 of 6 (permalink) Old 04-25-2014, 08:48 AM
First Name: Ronald
Johann, I bought an old DeWalt mod 740, cleaned it up, replaced carriage and motor bearings, put on a new top, aligned everything, and now it is very accurate and a pleasure to use.
the following has more info:
http://www.johnsonphotographic.com/g...l_Arm_Saws.pdf
http://www.asiteaboutnothing.net/cr_radial-arm-saw.html (lots of refs)
swarfmaker is offline
post #4 of 6 (permalink) Old 04-26-2014, 01:09 AM Thread Starter
First Name: Johann
Thanks so much. The info will help a lot!
post #5 of 6 (permalink) Old 04-28-2014, 10:18 AM Thread Starter
First Name: Johann
It is now really in a thousand pieces! Cleaned and needing
New carriage bearings. No wear and tear that I can see.
post #6 of 6 (permalink) Old 05-05-2014, 05:13 AM
First Name: Ronald
When assembling use dry lube where possible, especially on the column. I used Just a puf.
Keep us updated
Question about new DeWalt DW 611 router LBrandt General Routing 29 09-01-2017 10:55 AM
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 15 01-26-2015 02:30 AM
Ridgid or DeWalt xplorx4 Tools and Woodworking 8 08-12-2010 09:02 AM
Outlook Express problems BrianS Lobby 6 01-06-2008 07:23 AM
