Cutting precise angles - Router Forums
post #1 of 21 (permalink) Old 05-02-2014, 09:24 AM Thread Starter
First Name: Peter
Default Cutting precise angles
I want to make a stave drum and I'm not sure how to cut the angles. I want 12 staves which will mean a 15 degree angle for each cut. I have a choice of a router and a hand saw.
I have nothing to measure angles at the moment, I was planning on using trigonometry and measure things. I was going to make an angled jig to clamp my wood to and then run it along my router table. I'm not convinced that the router bit is completely perpendicular to the table though. The other option is a hand saw, but I think that will probably be less accurate.
What would you recommend?
DrillingThrough is offline
post #2 of 21 (permalink) Old 05-02-2014, 09:48 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Peter,
Comparing accuracy of cut with router table versus "hand saw" is like comparing a sniper rifle to throwing a rock. You can buy a protractor to measure angles for $1.00 at Wal*Mart. A good quality protractor or angle gauge for woodwork can be had for $15.00 or less...
OPG3
Tweak everything!
OPG3 is offline
post #3 of 21 (permalink) Old 05-02-2014, 11:47 AM Thread Starter
First Name: Peter
Originally Posted by OPG3 View Post
Peter,
I've just ordered an angle guage. I'll start making the jig soon.
post #4 of 21 (permalink) Old 05-02-2014, 05:01 PM
Hi, Peter; welcome!
You didn't fill out a profile, so other members wouldn't know whether or not you have access to a tablesaw(?).
For what you want to accomplish, sure, you could cut the staves out oversized, and hand plane them down to a perfect fit, but that assumes a lot of hands-on experience on your part. Might be a fun learning project, but don't expect a perfect fit first time out of the gate; that's going to take practice. But as I said, a great learning experience.
I've been working with wood since my teens, but that'd be a challenge for me.
Begging the use of a tablesaw is your best short term answer.
DaninVan is offline
post #5 of 21 (permalink) Old 05-02-2014, 07:10 PM
Country: Brazil
First Name: ClŠudio
Cutting angles on the table saw
at 12:30
https://www.youtube.com/watch?v=O1-LYCKbYG8
Botelho007 is offline
post #6 of 21 (permalink) Old 05-02-2014, 10:39 PM
I would also probably use a table saw but you can also buy a 15*bevel router bit (along with a variety of other angles).
post #7 of 21 (permalink) Old 05-03-2014, 03:11 AM Thread Starter
First Name: Peter
I haven't got a table saw. I only have two power tools, a drill and a router. A table saw would be ideal, but I haven't got anywhere to store it.
post #8 of 21 (permalink) Old 05-03-2014, 09:08 AM
rwl7532's Avatar
First Name: Ralph
Build a jig to hold the wood at a 15 degree angle. The jig should be adjustable. Then use a straight bit.
Use cheap wood for the staves until you have dialed in your jig.
Great project. You will learn the difference between theory and practice. (Practice wins)
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #9 of 21 (permalink) Old 05-03-2014, 01:05 PM Thread Starter
First Name: Peter
I started making a jig today but got the sizes completely wrong.
What's the best way to cut the pieces to size (not angle them, but just do the lengths and widths)? Would it be best to do one, and then use it as a template with the router? The lengths aren't as important (as the ends will be cut off later), but the widths must be the same.
What's the best way to make the jig adjustable? Nuts and bolts to adjust the height at the end of the ramp?
post #10 of 21 (permalink) Old 05-03-2014, 02:31 PM
rwl7532's Avatar
First Name: Ralph
You need 12 identical pieces to determine that your attempts at 15 degree cuts are good. Likely they won't be. Which is why using cheap wood is a good strategy.
rwl7532 is offline
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 11:11 AM
Precise Slot Cutting Bit randymang Router Bits - Types and Usage 7 03-28-2012 11:42 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
