How thick Should The Lid Of A Cedar Chest Be? - Router Forums
post #1 of 13 (permalink) Old 05-21-2014, 12:13 PM Thread Starter
First Name: Jerry
Default How thick Should The Lid Of A Cedar Chest Be?
O.K., I have asked, privately, three member of the this forum this question but have not heard from them yet, they just have not had time to reply to me so I'm asking on the forum to hear what the consensus on the question will be.
Right now the material being used is only .560" thick but the cedar lining has not been added. The cedar will be the material that will dictate the final thickness. I did not plan on the QS white oak to be this thin but due to shortage of material and some mistakes, the thinner stock is all that I am left to work with at the moment.
Jerry
Jerry Bowen is offline
post #2 of 13 (permalink) Old 05-21-2014, 12:37 PM
paduke's Avatar
How much weight will it carry? Over what span? Are you doing Inlay
Are you cross grain the oak and cedar? How thick is your cedar?
Most chests have storage in lid will yours ?
paduke is offline
post #3 of 13 (permalink) Old 05-21-2014, 12:49 PM Thread Starter
First Name: Jerry
The cedar will run cross grain. The span will be 36" wide and 20" from from to rear. No inlays, no storage in the lid. I'd like it to be strong enough so that it will not flex if if person up to 200 lbs. might accidently sit on it. I wanted it be about 1.5" thick but told that iit way to heavy and way to thick but not told how much so.
Jerry
post #4 of 13 (permalink) Old 05-21-2014, 01:14 PM
kp91's Avatar
First Name: Doug
Jerry,
1 inch should be plenty.
Can't wait to see pictures!
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #5 of 13 (permalink) Old 05-21-2014, 01:38 PM Thread Starter
First Name: Jerry
Originally Posted by kp91 View Post
Jerry,
Doug, thanks for the reply and suggestion.
The build is going slow, but eventually you'll see photos, I hope.
Jerry
post #6 of 13 (permalink) Old 05-21-2014, 08:07 PM
lenh's Avatar
First Name: Len
Jerry
Jerry, I just finished cedar chest where the top was 3/4 x 19 x 41 cherry including the breadboard ends. I made it so that one could sit on it. No problem supporting my 230 lbs. Not sure how much strength the cedar lining would add. If you have the top cut to size can you support it where the chest sides would be and then sit on it and see what happens?
Name:	Hope chest.jpg
lenh is offline
post #7 of 13 (permalink) Old 05-21-2014, 09:33 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Jerry
When you asked the question privately you failed to mention that it had to withstand 200 lbs., in which case I would have answered a minimum of 3/4". I'm certain that you would receive a great deal of advice if you were to post a rough drawing.
Harry
harrysin is offline
post #8 of 13 (permalink) Old 05-22-2014, 07:23 AM Thread Starter
First Name: Jerry
How many times to I have to tell you that I can't see well enough to draw sketch.
After adding the cedar the lid will be about one inch thick.
Jerry
post #9 of 13 (permalink) Old 05-22-2014, 08:25 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Here are the facts, structurally. Two thicknesses cannot be considered as one thickness unless they are working together. Question...How strong would plywood be without the glue between the veneers? Answer...Not very strong at all - there is nothing but an itty-bitty amount of friction to help the layers work together. If the two "wythes" (the proper structural term) are made to work together via a good glue joint - your situation should work fine. As said above, use perpendicular grain directions and the glue.
OPG3
Tweak everything!
OPG3 is offline
post #10 of 13 (permalink) Old 05-22-2014, 09:09 AM
harrysin's Avatar
First Name: Harry
Jerry
Have you never considered a camera and big screen monitor? Such systems, usually with an X Y table have been used by the vision impaired for many, many years to read books. Such a set-up would also make setting your fence a simple matter.
Harry
harrysin is offline
Cedar Chest: Just in Time for Xmas bcfunburst Show N' Tell 26 02-11-2014 11:49 AM
lining a cedar chest greg j New Member Introductions 6 11-29-2013 09:09 PM
How do i line a cedar chest? Jerry Bowen Tools and Woodworking 10 10-22-2012 05:54 PM
Finishing an aromatic cedar chest drbbob The Finishing Touch 8 03-11-2012 01:41 PM
Small Cedar Chest cchowland Show N' Tell 3 02-03-2012 11:47 AM
