Need Help Finding A Closer For Chest - Router Forums
post #1 of 31 (permalink) Old 05-22-2014, 02:13 PM Thread Starter
First Name: Jerry
Default Need Help Finding A Closer For Chest
I'm to the point of shopping for a "soft closer" for a cedar chest lid. The lid without the frame weighs 19 lbs. It is 18" x 36" and one inch thick. I have looked on the web but have not found what looks right to me so am asking member of the forum for help finding something that will work.
I think that I may have the piano hinge spotted.
Jerry
Jerry Bowen is offline
post #2 of 31 (permalink) Old 05-22-2014, 02:19 PM
Semipro's Avatar
First Name: John_*
Semipro is offline
post #3 of 31 (permalink) Old 05-22-2014, 02:36 PM
MT Stringer's Avatar
Jerry
Hmmm, I thought we had already had this discussion. Did you decide against the Rockler lid protectors?
MT Stringer is offline
post #4 of 31 (permalink) Old 05-22-2014, 04:06 PM
First Name: Dick
We did but Jerry and I are just old farts that can't remember s...tuff.
Dick
Where there's a Willis there's a way!
Willway is offline
post #5 of 31 (permalink) Old 05-22-2014, 04:42 PM Thread Starter
First Name: Jerry
Mike, your memory is much better than mine, I actually don't recall. I know that I had looked at torsion hinges at Rockler which will not handle a lid this heavy and are being discontinued anyway. If we talked about another type of closer, which we probably did if you say that we did, I just don't recall and/or didn't make a note of it as I was not that far into the build. Sorry if I offended you by asking about something that you thought we had already covered. It sort of sounded like it irritated you just a bit, maybe I read it wrong.
Jerry
post #6 of 31 (permalink) Old 05-22-2014, 05:25 PM
Here is your original post.
http://www.routerforums.com/lobby/46...se-hinges.html
The Rockler lid protectors look similar to the ones SemiPro linked to.
Getting old is a pain I feel every day. :-(
Good luck in your search.
post #7 of 31 (permalink) Old 05-22-2014, 07:28 PM Thread Starter
First Name: Jerry
Mike, Mike, Mike, I was not argueing with you, I just said that I had forgotten, settle down, I believe you.
Jerry
post #8 of 31 (permalink) Old 05-23-2014, 12:03 AM
Hey, no problem on this end. I know you will find the right item for your chest. Post some pics when you get through. I have no doubt it will look great.
post #9 of 31 (permalink) Old 05-23-2014, 07:12 AM
First Name: Andrew
Send a message via Skype™ to Roodog
Hey mate...why not try gas struts? Like the ones that are on hatchback cars. I've done that before with my daughter's toybox years ago and it worked very well. You can even get them second-hand but they've been re-gassed so they are really like new.
Roodog is offline
post #10 of 31 (permalink) Old 05-23-2014, 07:49 AM
First Name: Dennis
Hi Jerry
I used some Rockler lid stay torsion hinges not that long ago on a chest and they work perfectly with no extra arm type hardware to get in the way. My lid was over 20 pounds and the hinges hold it at any position and yet it is very easy to open and close. The only problem may be that it is designed for 3/4 inch walls on the chest so that may require some modification if yours are a different thickness. They aren't cheap!!
Good luck
Dennis
routergieck is offline
Finding the center line of a board's edge. rwl7532 Tools and Woodworking 36 04-22-2013 03:44 PM
need help finding 6' wood rods econlow Tools and Woodworking 4 05-10-2009 04:09 PM
help in finding k.birrell Tools and Woodworking 1 03-15-2006 01:30 PM
help in finding router bit woodhead Router Bits - Types and Usage 1 03-14-2006 02:16 PM
Finding Dead Center cfm Jigs and Fixtures 1 11-13-2004 10:22 AM
