how do i make double chamfered shiplap siding - Router Forums
post #1 of 9 (permalink) Old 05-25-2014, 08:45 PM Thread Starter
Default how do i make double chamfered shiplap siding
I am having to make my own siding for a remodel project I am doing on my house. I initially thought I had tongue and groove with a v notch. but after removing a window, I could see it is actually a shiplap but it is chamfered or what I have seen called v notched on both side, when 2 pieces are assembled, it looks like a v groove. The reason I am having to make it is the size is odd. It is 9" coverage width. If anyone has a suggestion how I should go about milling this out myself. I am not a novice with my router and table, but I am not a master with it either. Ideally it would be nice to find one bit that will make the lap and the v cut in a single pass.
Thanks You. Jim
Ruebus is offline
post #2 of 9 (permalink) Old 05-25-2014, 08:51 PM
Semipro's Avatar
First Name: John_*
Jim, welcome to Router Forums, glad to have you join us, I'm positive the members of the community would be more than willing to answer any questions you have
If got a picture it would help( you can post if it is on your computer)
Thank You John
Semipro is offline
post #3 of 9 (permalink) Old 05-25-2014, 09:20 PM
BCK
First Name: BC
welcome aboard....hopefully someone may have the info to help...but can I suggest a picture to show as much of the joint/fitting you can may also help,,enjoy
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #4 of 9 (permalink) Old 05-25-2014, 09:33 PM
First Name: Don
Could be done on table saw, cut your rabbit with a dado blade, then go back & cut your 45 deg. angle.
Making sawdust & scraps all at the same time
Salty Dawg is offline
post #5 of 9 (permalink) Old 05-25-2014, 11:48 PM
Ahh, it just came back to me! I haven't used that for a couple of decades.
I think if I was doing it, I'd do the T&G machining first, then run the center 'v' then the two outside 1/2 v's .
Don't even bother trying to do the T&G with a chamfer at the same time...absolutely no upside if things don't work out. I'll see if I can find a cross-section for the members that aren't familiar with it.
DaninVan is online now
post #6 of 9 (permalink) Old 05-25-2014, 11:52 PM
Is this it, Jim?
Scroll down to #5 at this link...
Wood Siding Patterns * WWPA Wood Siding Patterns
OH! Welcome!!
post #7 of 9 (permalink) Old 05-26-2014, 01:50 AM
First Name: Don
Originally Posted by DaninVan View Post
Is this it, Jim?
OH! Welcome!!
sounds like he is looking for #6 pattern, good find on the link.
post #8 of 9 (permalink) Old 05-26-2014, 03:05 PM
MAFoElffen's Avatar
Most places-- Having a matching pair (2 sets) of custom moulding cutter knives made would be around $30-$50....
But yes, what Dan said... Can be done with a router in 2 steps for each profile (2 finished compound profiles).
MAFoElffen is offline
post #9 of 9 (permalink) Old 05-26-2014, 06:13 PM
old55's Avatar
First Name: Ross
Welcome to the forum Jim.
Ross,
old55 is offline
How to Make a Raised Panel Door learnexperience General Routing 2 09-06-2011 08:39 PM
How to Make a Simple Clock Using Box Joints learnexperience Tools and Woodworking 2 08-15-2011 09:21 AM
How to Make a Pencil Box learnexperience Tools and Woodworking 2 08-09-2011 11:45 PM
How To Make a Box with a Box Joint learnexperience General Routing 7 08-07-2011 07:07 AM
