V grooved doors - Router Forums
post #1 of 3 (permalink) Old 05-27-2014, 08:06 PM Thread Starter
roofner's Avatar
First Name: Gary
Default V grooved doors
What angle would you set your table saw to rip v groves about 1/4 inch deep? I have already built a case covered with beaded board and want to space the v groves about same distance apart as the beads . Doors will probably be made up of glued up pine boards. Normally you overlap the doors by 1/2 inch minus 1/8 between the 2 doors is that correct. These are my first doors I have built. Anyone built this style door and remember the angle used?
roofner is offline
post #2 of 3 (permalink) Old 05-27-2014, 11:15 PM
Semipro's Avatar
First Name: John_*
Gary
Would it not be easier to use a v bit in a router with a straight edge,I believe the angle would be 45į.
You are correct usually half inch overlay 1/8" between the doors.
Semipro is online now
post #3 of 3 (permalink) Old 05-28-2014, 07:41 AM
I agree with John. You could use a table saw but the angle would have to be 45* and the bottom might not be smooth anyway even then. A router bit will do a much better job. If you look in my uploads you'll seee a diagram of a grooving jig. If you rip strips the width you want the grooves to be on your TS that will take care of your spacing. Just add another spacer strip for each groove.
Can I use 3/4" Plywood for Sliding Closet Doors? redzone Tools and Woodworking 6 03-01-2012 09:51 AM
Doors, doors and more doors! mailee Show N' Tell 2 03-16-2011 09:01 PM
French Doors & Mullions - Router Bit? FrenchDoor Router Bits - Types and Usage 20 10-09-2009 09:04 AM
