jointer alignment - Router Forums
post #1 of 15 (permalink) Old 05-28-2014, 08:11 PM Thread Starter
woodcurls's Avatar
First Name: gary
Default jointer alignment
I have acquired an older craftsman jointer(model 113.206931, serial #3251.P0008).
I can not get the infeed table to line up with the outfeed table. I have the manual for it and the adjustments seem pretty straightforward. Am I missing any tricks to get them to line up, or is it worn out and should be scrapped?
Any help will be gratefully accepted.
woodcurls is offline
post #2 of 15 (permalink) Old 05-28-2014, 08:17 PM
Hi Gary, on the jointer, the infeed table has to be slightly below the outfeed table, not level [by the amount you want to take off].
The blades have to be level with the outfeed table.
If you have the manual, this should be explained.
Sydney, Australia
jw2170 is offline
post #3 of 15 (permalink) Old 05-28-2014, 09:19 PM
lenh's Avatar
First Name: Len
Gary, I'm guessing that you mean that the tables are not co-planer. Does you manual talk about gib adjustments?
lenh is offline
post #4 of 15 (permalink) Old 05-29-2014, 03:50 AM
First Name: jimmy
Send a message via Yahoo to bowdean
hey gary, over the last 38 years of wood working have found that the jointer planer is one of the most finger eaters you can use. be safe my friend!!!! later bowdean.
bowdean is offline
post #5 of 15 (permalink) Old 05-29-2014, 08:11 AM
First Name: Gary
Gary,
If you are referring to the infeed table and the outfeed table not being parallel when the infeed table is raised...Refer to the manual Pages 14 thru 16. I have the same Jointer and it is a very good jointer.
File Type: pdf Craftsman Jointer Owners Manual L0805383.pdf (3.06 MB, 87 views)
gmercer_48083 is offline
post #6 of 15 (permalink) Old 05-29-2014, 12:29 PM
First Name: Jerry
I think that all of the right questions have been asked, but I'm still not clear from your questions what you mean for sure about not being able to get the table in line. As James said the infeed table top top needs to be parallel with out feed table but not on the same level as the difference in height dictates the depth of cut. However, if you are referring to alignment in regard to both of the table being square with the fence, well, that's another matter. I had a PC table jointer that was not set up as far as the tables both being square with fence, I had to take the in feed table off and shim it into square.
Can you elaborate a little more on what you are referring to as far your problem is concerned.
What James said about the out feed table being common with the top of the blades is the secret of not getting any snipe. I you do get some snipe, you need to adjust the height of the out feed table. This is a very critical adjustment, but well worth the time it takes to tweak it into position and once st you should not have to mess with it again unless to check it when you change blades.
Jerry
J
Jerry Bowen is offline
post #7 of 15 (permalink) Old 05-29-2014, 03:34 PM Thread Starter
woodcurls's Avatar
First Name: gary
I'll see if I can explain it better.
The infeed is not parallel to the outfeed table. I know that the infeed needs to be lower than the outfeed to make the cut. There are four adjusting nuts underneath the infeed table when I use a straightedge and feeler gauage to get them parallel to the outfeed table table and adjust to make the cut the tables are no longer parallel.
Thank you for the prompt replies. I am open to any more suggestions anyone may have
post #8 of 15 (permalink) Old 05-29-2014, 03:43 PM
First Name: Jerry
Gary,
It sounds like you probably are more mechanical savvy than I am, I got into this thread because of the experience I have had with both the PC bench jointr and my newer Grizzly 6" jointer.
Apparently the mechanisem that adjusts the in feed table does not stay in place onece you level the table and lock the adjustment screws, would that be correct? If so can you set the in feed table a little out of alignment so that when the screws are tightened the in feed tables ends up in proper alignment. Maybe the tightening of the screws are pulling the table further than it should be. Are we onto anything or not?
Jerry
post #9 of 15 (permalink) Old 05-29-2014, 03:45 PM
Gary; is something badly worn? It sounds,from your description that you adjust for parallelism, but it immediately goes out of alignment when you drop the infeed for depth. Is that a reasonable interpretation of the issue?
What's the general condition of the whole machine? I'd be worried that it's been dropped, or otherwise warped.
My mantra:
It worked before. Now it doesn't What's changed
DaninVan is offline
post #10 of 15 (permalink) Old 05-29-2014, 03:46 PM
Let me punctuate that for English...
It worked before. Now it doesn't. What's changed?
DaninVan is offline
J.D. Wallace 8" jointer AxlMyk Tools and Woodworking 15 10-26-2015 10:29 AM
Installing Jointer Knives on a DJ20 8" Delta Jointer TRN_Diesel Tools and Woodworking 9 06-23-2014 08:53 PM
Jet JJ-12 Jointer Information? ORBlackFZ1 Tools and Woodworking 6 03-22-2014 01:10 AM
Let Me Tell You About My New Jointer Jerry Bowen Tools and Woodworking 8 06-19-2012 12:24 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
