Air compressor questions - Router Forums
post #1 of 13 (permalink) Old 06-04-2014, 10:51 AM Thread Starter
roofner's Avatar
First Name: Gary
Default Air compressor questions
Anyone have this brand gets good reviews best in the price range I want to pay from my Lowes store. I have not been happy with the cheap hose I have so when upgrading . I am leaning toward the polyurethane hoses but only come 1/4 . Is it a big deal the 1/4 verses 3/8 diameter.
Reason is from what I have read the polyurethane hoses don't kink and are flexible and very durable.
The pancake compressor are they as durable as full size or am better off with a full size on wheels.
roofner is offline
post #2 of 13 (permalink) Old 06-04-2014, 11:32 AM
MikeMa's Avatar
I think the import part for the hoses is that they are rated for at least the max PSI for your compressor. Most are.
As for the pancake compressor, it really depends on what you are using it for. All I have is a pancake compressor. It is great for nail guns, as blower, and for the occassional tire or pool/kids toy inflation. The key is not letting the motor run too long as it gets hot and can over heat. I have used mine for HVLP for spraying shellac, and I would not recommend it as you are risking burning out the motor.
If all you are mainly going to be doing is running a brad and finish nailer, the pancake will be fine. If you want to be doing more than that, you are going to need bigger, in some cases MUCH bigger. Also the type of motor and compressor matters as well. Most pancake compressors are single stage, meaning they only fill the tank on the push stroke. Bigger compressors are available in two stage where the tank is filled on both push and pull stroke. Also the oiled compressors are preferable over the oilless ones as they tend to last much longer.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 13 (permalink) Old 06-04-2014, 08:48 PM
berry's Avatar
First Name: Berry
I agree with Mike. A pancake compressor works fine for the nail guns in your stop and blowing the kids toys but I don't think it will work on sanders and other tools using compressed air. I have no experience with any hose other than the one that came with the compressor.
May the grain be ever in your favor.
berry is offline
post #4 of 13 (permalink) Old 06-04-2014, 09:29 PM
First Name: Don
Flexzilla. hoses are the pretty good. On the compressor, look at the air tools you use, the one that uses the most cfm, then match the compressor to that,you want the compressor to put out more cfm than the air tool, this will keep the compressor running to much.
Making sawdust & scraps all at the same time
Salty Dawg is offline
post #5 of 13 (permalink) Old 06-05-2014, 12:06 AM
Unless you're only using low volume tools (e.g. pin nailer) 1/4" hose is too restrictive of air flow.
A few years ago I got a 3/8" urethane hose at Harbor Freight- it seems to be of reasonably good quality at a good price. My experience with that hose has been that it isn't terribly flexible- it really has a coil "memory", even after trying tricks I've used for garden hose, such as laying stretched out on the lawn on a hot sunny day. OTOH, it is strong, and doesn't kink easily. I find that rubber hoses are much more flexible, in that they uncoil easily.
The real advantages of urethane for me are that it's pretty slippery, so doesn't get snagged as easily when pulled around objects and corners. Also, it's very light, so invaluable for spray painting on a ladder, when you're lifting a long section of hose from ground level.
Just my .02 as an occasional compressor user.
jdonhowe is offline
post #6 of 13 (permalink) Old 06-05-2014, 07:39 AM
I have found the oil-less, diaphragm type compressors are much more noisy than the oil type. Gets very annoying with time and in some cases is unbearable. Be sure to hear one run before you purchase. My neighbor has one that we can hear very clearly in our house with both his and my garage doors closed!
senebraskaee is offline
post #7 of 13 (permalink) Old 06-05-2014, 08:00 AM
The oil less compressors run for about 500 hours before needing rebuild, and they can over heat if run too long, which are two reasons they're suited for limited use and shorter run times. Oiled compressors require a little attention, but last a long time. They are usually much more expensive, but a must for prolonged use or if you are using multiple devices. Oiled compressors are usually larger as well, which is obvious. I use the 1/4 inch for nailers. Have the pancake type and it is pretty noisy.
post #8 of 13 (permalink) Old 06-05-2014, 08:35 AM
First Name: ROBERT POWELL
The senco hotdog style is great for wood working guns. The poly hose is also great. Though it is not large enough for air powered tools.
IBUILD2 is offline
post #9 of 13 (permalink) Old 06-05-2014, 10:25 AM
richjh's Avatar
First Name: Rich
I purchased a 100ft 1/4" PVC hose from Harbor Freight to run a roofing nail gun and it worked great. I gave my small compressor to my son when he moved after I got a Coleman 27gal. so I use this hose a lot more now that I don't have the portable one. The only downside I ran into was the outer jacket wanting to melt on the hot roof so I had to try and keep it off the hottest parts of the roof while working. I just used it to drive a texture gun for a home renovation project and it supplied plenty of air and that tool uses a high volume of air but only at 40PSI.
Rich
Basically, a tool is an object that enables you take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself - Dave Barry
richjh is offline
post #10 of 13 (permalink) Old 06-05-2014, 01:34 PM
First Name: Trevor
I have a husky 8 gal oil compressor around $100, hf hose that works good for my basement shop needs.
TrevortdogR is offline
Help - where do you locate your dust filter? allthunbs Woodshop Dust Control 42 09-02-2018 09:29 PM
Hello and a question about air compressors Joe T CNC CNC Routing 1 11-07-2013 03:48 AM
Air Compressor Help tiir22 Tools and Woodworking 19 08-21-2012 01:15 AM
Dylos Air Quality Monitor Group Buy BigJimAK The Bargain Bin 0 07-28-2011 11:46 AM
