Want to ADD soft-start to a tool - Router Forums
post #1 of 8 (permalink) Old 06-11-2014, 05:40 PM Thread Starter
First Name: Phil
Default Want to ADD soft-start to a tool
I know there are quite a few woodworkers that want to disable the soft-start feature of their routers (so they can use an external speed control). I have the opposite dilemma.
I purchased a portable table saw. I like it quite a bit, but it doesn't have soft-start and the kick is something else when it stars. It kicks so hard it deflects a blade enough to chew into the edge of a sled.
Does anyone know of any variable speed controls that will work with a universal motor that provide a soft-start feature?
I found a video on youtube which pretty much shows what I want to accomplish, but the device was apparently a prototype, I need something I can buy.
I cannot post URL's to Youtube but if you go to youtube and search for "uQmnpqHjCyM" (no quotes) you will find a link to the control.
Thanks!!!
Phil Thien
cgallery is offline
post #2 of 8 (permalink) Old 06-12-2014, 08:48 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
There are many on the internet but the prices appear to be at least as much as a decent new saw. I can't help wondering what sort of saw you have that behaves in such a manner, it doesn't seem "normal" to me.
Harry
harrysin is offline
post #3 of 8 (permalink) Old 06-12-2014, 10:04 AM
First Name: Duane
Speed control'
Start on slower speed,then flip to full speed?
Think I would try a different blade first, though! I'd be a bit leary of one with that much flex.
Dmeadows is offline
post #4 of 8 (permalink) Old 06-20-2014, 12:17 PM
MAFoElffen's Avatar
Originally Posted by Dmeadows View Post
Speed control'
I would wonder about the same... or maybe too much run-out in the arbor bearings???
MAFoElffen is offline
post #5 of 8 (permalink) Old 06-21-2014, 12:31 AM
RainMan 2.0's Avatar
X2
There is no way that the blade is distorting during start up IMO . You've got bigger problems to deal with here .
I'm betting on the arbor bearing also . I was thinking maybe the trunnion was loose or worn but I don't think it would straighten itself out with the centrical force of the blade , but the arbor might
RainMan 2.0 is offline
post #6 of 8 (permalink) Old 06-22-2014, 09:17 PM
First Name: Duane
Originally Posted by RainMan1 View Post
X2
Rick, back in the day, when I was repairing machinery, I have seen thin kerf blades(I use the term loosely!), that would very easily deflect +- 1/4". The owners never could figure out why the saw didn't cut well!
A manufacturer that I won't name had a bunch saws sold with those "blades" on them!
Kind of scary, but the saws were not worth much more either!
Dmeadows is offline
post #7 of 8 (permalink) Old 06-22-2014, 11:05 PM
Wow I wouldn't have believed it . If that's the case then he should upgrade his blade maybe?
I am using Freud saw blades and I know there not distorting because if they were you would think they would damage a zero clearance insert?
Just a thought
post #8 of 8 (permalink) Old 06-23-2014, 01:32 AM
eccentrictinkerer's Avatar
First Name: J.D.
Here's a way to get a kind of soft-start.
Wire a high-wattage (200 watt or higher) light bulb in series with the motor with a single-pole switch wired in parallel with the bulb.
When the saw reaches it's top speed, flip the switch on (this shorts the bulb) to give full voltage to the saw.
Experiment with different bulbs to get desired results.
I keep a 1,000 watt bulb on my bench to use as a current-limiting device when testing motors.
Worst that can happen if the motor is shorted is the bulb lights to full brilliance! (Wear sunglasses!).
http://www.amazon.com/1000PS52-CL-Li.../dp/B007XKWZL2
eccentrictinkerer is offline
Tool Review Guidelines ~ READ BEFORE POSTING Mark Tool Reviews 5 01-18-2020 09:11 AM
Why Is It So Darn Hard To Know How To Properly Start A Thread Jerry Bowen Lobby 22 04-13-2014 06:51 PM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-07-2012 11:17 PM
Soft start for an old Makita 3600 router brogan General Routing 2 07-17-2008 01:08 PM
