Question About Whiteside Inlay Kit - Router Forums
post #1 of 7 (permalink) Old 06-14-2014, 08:03 PM Thread Starter
First Name: Jerry
Default Question About Whiteside Inlay Kit
Just got a copy of the Whiteside Inlay Kit, have not used it yet, but have been looking at it and watching a you tube video on how to use it.
My question is to others that have and have used the kit. The bearing that is to be removed after cutting the recess for the inlay does not come off very easy at all, I got it off once with my fingers but can't get it off in that manner again. Oh, I'll get it off and will be careful to not mar it, but am wondering if others have run into the same problem or not.
Jerry
Jerry Bowen is offline
post #2 of 7 (permalink) Old 06-14-2014, 10:12 PM Thread Starter
First Name: Jerry
The concept works as expected, did my first inlay, didn't spend much time getting the template perfectly round, just wanted to try to see how the new router and inlay kit would work. Not very fancy, but am sure that I can do what ever I want to do with the set up now.
Jerry
post #3 of 7 (permalink) Old 06-14-2014, 11:15 PM
Semipro's Avatar
First Name: John_*
Looking good Jerry
( that collar has to be tight would not want it to fall off would you)
Semipro is offline
post #4 of 7 (permalink) Old 06-15-2014, 05:30 AM
Some collars have a small grub screw and some just have a rubber ring inserted into the collar.
Sydney, Australia
jw2170 is offline
post #5 of 7 (permalink) Old 06-15-2014, 06:18 AM
First Name: del
Jerry
this is the one i have and have no problum's with the little coller , you may have to use a sharp knife blade under the collor ? other wise it works good
del schisler
port st. lucie, florida
del schisler is offline
post #6 of 7 (permalink) Old 06-15-2014, 07:14 AM Thread Starter
First Name: Jerry
I simply put a piece of masking tape over the bearing and used a pair of needle point pliers to lift the bearing off, it gook almost no pressure, it's just bit to small to grip with my fingers. All I O.K., just need some practice on cutting the template out find a way for me to see better when doing the cut out.
Jerry
post #7 of 7 (permalink) Old 06-15-2014, 08:27 AM
TwoSkies57's Avatar
Thumbs up
That'll work!!!
Skipper the Penguin
Last edited by TwoSkies57; 06-15-2014 at 08:53 AM. Reason: gotta give ya a thumbs up!!
TwoSkies57 is offline
Inlay Kit Question Dodgeboy77 Jigs and Fixtures 22 06-30-2013 01:08 AM
Bushing set vs. inlay kit ? mharwell01 Guide Bushings and Templates 7 02-02-2008 04:44 AM
