Table saw fence run out - Router Forums
post #1 of 16 (permalink) Old 06-19-2014, 09:10 PM Thread Starter
RainMan 2.0's Avatar
Default Table saw fence run out
Guys and gals this is a tough question . I have talked with a journeymen carpenter and he claims he runs his table saws fence run out over an 1/8th of an inch to avoid sniping with hard wood . (That's measurement is from the front to the back of the fence)
I thought that was a lot and tried .005" from the front to the back of the fence .
It worked fine till I had a piece of tall wood and the blade up fully as it started burning and kicked out .
I set the fence to .025" and had no issue ,but I thought that was also a lot as I've read guys setting there fence to zero runout with the blade ?
Measuring a Canadian bill I get .0035" with my dial gauge to give you an idea .
Btw I checked my blade to the miter slot and get .002" ,and that's with the .002 extra being between the back of the blade and the fence so it's actually helping by not squeezing the material into the fence .
Anyone else have a measurement they prefer ?
RainMan 2.0 is online now
post #2 of 16 (permalink) Old 06-19-2014, 09:16 PM
vindaloo's Avatar
First Name: Angie
I don't have any run-out but I do have a splitter to avoid the grab. Sometimes I move the sub-fence so it ends just after the front teeth have cut the wood, that allows the wood to be free from the blade and not squashed between blade and fence.
vindaloo is offline
post #3 of 16 (permalink) Old 06-19-2014, 10:12 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Even with a splitter the out-feed end of the fence should be slightly wider than the in-feed which ensures that the wood can't jam and be forced out in the direction of the operator at a great rate of knots. I have found that half to one millimeter is all that is required.
Harry
harrysin is offline
post #4 of 16 (permalink) Old 06-19-2014, 10:13 PM
Al B Thayer's Avatar
First Name: Al
Default Oh you dont? Do you?
I've heard of this setup but for me it would conflict with many of the other cuts you make on the TS. Like dados.
I've never experienced snip on the table saw unless I let the wood goes to the right by mistake. Maybe there is another problem with his saw that he isn't aware of like the blade isn't aligned with the slot.
In all the years of using my Unisaw. I have never had a board kick back. I have seen it ride up the blade a bit but no kick backs.
I'd set it straight.
Al
Al B Thayer is offline
post #5 of 16 (permalink) Old 06-19-2014, 10:31 PM Thread Starter
Al
Hey Al , blade to miter slot is .002
And the bigger opening of .002" is at the rear so that wouldn't be it
post #6 of 16 (permalink) Old 06-19-2014, 10:43 PM Thread Starter
Harry I was having good success at .025" and just did the conversion and that comes to .64mm
I think you called it
Al
Tell you the truth Al if I was using the dado I think I'd reset the fence to zero . I agree with you there .
post #7 of 16 (permalink) Old 06-20-2014, 12:45 AM
I have my fence out by "a smidgin"......
Sydney, Australia
jw2170 is offline
post #8 of 16 (permalink) Old 06-20-2014, 02:42 AM
harrysin's Avatar
First Name: Harry
1 smidgin = 0.75mm!
Harry
harrysin is offline
post #9 of 16 (permalink) Old 06-20-2014, 03:17 AM
1 smidgin = 0.75mm!
then what is the fuzz mine is set at???
Stick486 is offline
post #10 of 16 (permalink) Old 06-20-2014, 03:33 AM
MAFoElffen's Avatar
Default Just mine...
Mine is kicked out at .2mm, which is .007" in 36"'es. My sliding table is set kicked out about the same in 62". My crosscut fence is inside .2mm at 1400mm. The closest I seem to be able to keep mine is about 0.002". My panel saw doesn't have any miter slots (persay). The blade on that is set to the frame, then you adjust everything off that.
But if you break those down, on the rip fence (for mine), that's .002" per foot. Slider, .001" per foot, which the crosscut the same. Took a long time getting those that way... but my saw has "adjustments to dial that in.
I do make sure those are at least positive (kicked out). I have not noticed any snipe or difference w dado's... which I also use a lot.
A normal cabinet saw and other full size table saws usually have a 27" table. Harder to dial in on a shorter table... But my Rockwell is. Both saws, no snipe.
Personally, IMHO, .025" would be excessive. .25mm would be right there. I usually set other peoples saw's Rip fence's at within.005" to the blade and left miter. But I had gauges made up to make that easier. (like a 36" straight piece of 5/8" square key stock and a dial indicator. But I start out for truing the arbor and going from there. My jobsite saw, I also settle on within 0.005". It get's beat, travels in the truck and because it is not as solid, has to be tuned more often.
But it really depends on the saw... I would shoot for at least within 0.010 in 27". I do less than 25% of my cuts with the rip fence. About half of that other time I have my rip fence shifted right and flipped forward, out of the way. Same was with the Rockwell, but with using various sleds.
It's a compromise. Too little or a negative and you risk catching the work in a trap between the blade and fence. To much and it will tend to pull the work of the fence on the off-side, be rubbing the kerf at left-front toe of the blade, keeping pressure on the left side of the blade causing more heat on the left side. That shortens the life of the blade and causes a flutter looking cut. (more saw marks) That uneven heat and wear tends to dull the blade faster and shorten the blade life...
Having those dialed in does seem to have less drag on the work, have a better quality cut and extend blade life. But that is just what I've noticed over the years with my saws and cutting various density of woods. For me, that means less sanding and less tooling costs over the long run. The again, most people aren't doing cabinet, finish and mill-works.
MAFoElffen is offline
Table saw router table. Willway Table-mounted Routing 14 04-25-2013 12:35 AM
Kreg Router Table and Fence jeffk Table-mounted Routing 25 10-14-2011 06:25 PM
vertical table equals horizontal router paduke Table-mounted Routing 22 06-16-2011 07:15 PM
DIY Table and fence - finished! JohnWP Table-mounted Routing 6 01-30-2011 08:39 AM
