Raised Panel Doors! - Router Forums
post #1 of 14 (permalink) Old 06-24-2014, 11:00 PM Thread Starter
MT Stringer's Avatar
Default Raised Panel Doors!
Had a good day today building some raised panel doors. All parts were already cut out. However, today I realized I needed to trim the panels just a smidgeon to get them to fit. After trimming on the table saw, one last pass on the router table got the panels cut down to the right size and shape.
Note: I use space balls in the grooves so the raised panel will not only be self centered, it will be able to expand if it needs to.
The doors are glued in the joints, but not the panels. Clamps pull everything into square. My bench has a 90 deg set up so the clamps do their job nicely.
I would assemble one door and let the glue set for at least 45 minutes. Meanwhile, I would get the next door (or doors) ready. At first I had two doors clamped up but that didn't work so well because one of them blocked the table saw so I couldn't trim the panels. So I resorted to building one door at a time. I now have several others ready to go first thing tomorrow. Dang it. If only I had a bigger place to work. But then, it is air conditioned - 77 deg F. all day! :-)
All of the panels fit through the planer except for one set. So, I had to reorganize the tools and drag out the drum sander. Those two door panels are now ready for the router.
I still have a boat load of parts for 14 drawers and another ten doors. :-) It seems like it is taking a long time but at least things are going well...well almost. I did forget to cut one stub tenon on a rail and had to recut it. Of course the router bit wasn't set right, so it took a little trial and error to get it set up again...just to make one cut. :-(
A little sanding and these doors will be ready to be installed when I get the boxes built.
Name:	2014-06-24 14.18.24.jpg
Name:	2014-06-24 18.35.11.jpg
Name:	2014-06-24 18.35.23.jpg
Name:	2014-06-24 18.35.35.jpg
Name:	2014-06-24 18.35.51.jpg
Name:	2014-06-24 18.35.58.jpg
Name:	2014-06-24 22.22.10.jpg
MT Stringer is offline
post #2 of 14 (permalink) Old 06-25-2014, 01:36 AM
Semipro's Avatar
First Name: John_*
Keep plugging along one day you will be done lol
Semipro is online now
post #3 of 14 (permalink) Old 06-25-2014, 07:58 AM
John Bradshaw's Avatar
Good Job!!!
John Bradshaw is offline
post #4 of 14 (permalink) Old 06-25-2014, 01:00 PM
First Name: Don
Looking good Mike, save some work for me.
Making sawdust & scraps all at the same time
Salty Dawg is offline
post #5 of 14 (permalink) Old 06-25-2014, 02:30 PM Thread Starter
Come on over.
post #6 of 14 (permalink) Old 06-26-2014, 10:50 AM
First Name: Barry
So, what do you in your spare time
Barry747 is offline
post #7 of 14 (permalink) Old 06-26-2014, 12:36 PM Thread Starter
Sleep. :-)
post #8 of 14 (permalink) Old 06-26-2014, 01:40 PM
RainMan 2.0's Avatar
Originally Posted by MT Stringer View Post
Sleep. :-)
I don't believe Mike ever sleeps lol
He's got the energy of the energizer bunny rabbit on lithium ion batteries
RainMan 2.0 is offline
post #9 of 14 (permalink) Old 06-26-2014, 03:03 PM Thread Starter
I just made it home with three sheets of plywood and got it unloaded before the rain moved in. Now, it's me and the track saw going head to head. :-)
EDIT: Not energizer batteries, but I do need a little Spark daily! :-)
Name:	2014-06-26 15.06.31.jpg
post #10 of 14 (permalink) Old 06-29-2014, 06:55 AM
First Name: Alan
Two clamps and a 23 gauge pin nailer and you could have all those doors assembled in about 30 minutes.
Alan Bienlein is offline
Raised Panel Cutters Suitable For House Doors Gaia Router Bits - Types and Usage 2 01-27-2014 02:10 AM
Mitered raised panel doors bobj3 Table-mounted Routing 13 09-03-2010 12:37 PM
3 pass mdf raised panel doors (bits?) cabinetal Router Bits - Types and Usage 7 06-28-2010 09:50 AM
Raised Panel Doors Diane Horner New Member Introductions 5 01-06-2010 08:50 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
