Cutting hardwood - Router Forums
post #1 of 8 (permalink) Old 07-01-2014, 12:48 AM Thread Starter
First Name: Joe
Default Cutting hardwood
Hey guys,
I'm new to this forum and pretty keen to get into wood working. I've looked around and haven't found a straight answer and thought i'd ask you lot!
I have 2 x nice bits of solid acacia hardwood that i want to use as a table top. I want to make a cut in the wood (rectangle > about 300mm x 150mm) on one side. I know i could attack it with a jig and rout the edge but i want to keep the 'offcut' as one piece.
Essentially, what i'm doing is using the offcut as a lid.
What would be the best option here? i happy with a bit of a gap and rounded corners. Could i do several passes with a straight router bit with a template? There is an (expertly) drawn picture attached where the darker brown is the solid bit and the lighter colour is what i want to cut out and keep. I got various tools at my disposal but not the knowledge unfortunately!
Cheers,
Joe
jmilazzo is offline
post #2 of 8 (permalink) Old 07-01-2014, 06:44 AM
Hi Joe,
How thick is the timber and do you have a scroll saw?
Sydney, Australia
jw2170 is offline
post #3 of 8 (permalink) Old 07-01-2014, 01:13 PM
Semipro's Avatar
First Name: John_*
Hello Joe, glad you found us, it's great to have you as a member of the community, welcome to Router Forums.
Thank You John
Semipro is offline
post #4 of 8 (permalink) Old 07-01-2014, 02:22 PM
Nickp's Avatar
First Name: Nick
Originally Posted by jmilazzo View Post
Hey guys,
Cheers,
Joe
Welcome...
If it were my piece of wood I would jigsaw the short side and plunge cut the long side (multi-tool, like Fein, etc...), then a bit of cleanup...assuming the thickness doesn't prevent it...
Good luck...Nick
Nick
Nickp is online now
post #5 of 8 (permalink) Old 07-01-2014, 11:41 PM Thread Starter
First Name: Joe
hey guys,
thanks for the tips.
the wood is about 26mm thick and i don't have a scroll saw. The slab of wood may be to big as it's about 2200mm x 600mm x 26mm . I think i might go at the short cuts with the jigsaw then work my way from there!
Cheers
jmilazzo is offline
post #6 of 8 (permalink) Old 07-02-2014, 01:47 AM
MAFoElffen's Avatar
hey guys,
Cheers
It helps out if you fill out your profile with listing tools you have so that others can recommend techniques geared to what you have... Otherwise we're guessing what your have and reaching by throwing out guestamations. I held off a bit until I could get a feel of what you had and your skill level.
Realistically, the easiest way I can think of doing that would be to lay out the saw marks... I would then ruff cut it out with a circular saw. If you aren't familiar with an inside blind cut with a circular saw... It is a not a technique for the light-hearted and needs practoce to do it safely and accurately.
What you do-- You position the saw over the where the blind cut will be, Youlay the leading edge down onto the work with the trailing edge lifted off the work. You rotate the gaurd back and hold it there, so it exposes the blade. you hold the saw with the blade just off the work as you start the saw with the blade off the work. You lower the lifted trailing edge until the blade slowly cuts through the edge and the balde is through the work piece.the top of the cut will be from inside corner to inside corner. You then cut the cuts from the edges to those inside corners.
The underside of the cuts will not be to the corners. They will be cut short of the corners. I finish those off with a saber saw, jig saw, pull saw or crosscut saw.
If the length of the cut will be short, adjust the blade on your saw up so it just gets through the material. On small cuts, like in cabinets, siding, paneling, etc, we usually use a smaller diameter bladed saw such as a 5-1/2" circular saw of double-cut kick saw.
If all you have is hand tools, then drill pilot holes near/inside the corners to get a saw cut started on your indie cuts and reverse directions to get clean cuts into the corners.
On getting a clean finish cut on hardwoods, before you lay it out, put down blue masking tape, lay it out, then score the line with a knife. Cutting through the surface grain. you'll cut without appreciable tearout of the surface fibers. If you need support for the cut to get a straighter line, clamp pieces of wood to help you guide your saw.
Sorry for the guesses, but the best I could do on the info given.
MAFoElffen is offline
post #7 of 8 (permalink) Old 07-03-2014, 02:35 AM
vindaloo's Avatar
First Name: Angie
Jigsaw in from the edges, then fret saw across.
vindaloo is offline
post #8 of 8 (permalink) Old 07-03-2014, 05:05 AM
Question jigsaw and ....?
hey guys,
Cheers
What tools do you have or plan to buy, Joe.
It is very hard to advise if you only have a hammer and chisel.......LOL.
Sydney, Australia
jw2170 is offline
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 11:11 AM
Profile Cutting Options BobCAD CAM aldepoalo CNC Routing 0 02-08-2012 10:49 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
