Having problem with Triton TRA-001 router - Router Forums
post #1 of 16 (permalink) Old 07-07-2014, 12:12 AM Thread Starter
Default Having problem with Triton TRA-001 router
It is a pleasure to finally join this forum. I have a problem that I am stumped with. I bought a brand new Triton Tra router used only twice and I am running a White Side flush trim 2" cutting length, 1/2" cutting diameter, 1/2" shank bit. The problem that I am having is at medium to high rpms the router is making a noise for example when you make your car engine top out and hit the rev limiter the rpms jump up and down like something is slipping. Its making poor cut quality and the bit is jumping. I have also tried a CMT 2" length bit and smaller bits and having same problem. What could be wrong with the router? Forgot to mention I am running this router in a router table. Any help would be greatly appreciated.
smg119 is offline
post #2 of 16 (permalink) Old 07-07-2014, 12:24 AM
Semipro's Avatar
First Name: John_*
, welcome to Router Forums, glad to have you join us, I'm positive the members of the community would be more than willing to answer any questions you have
I am not familiar with that router but we have a lot member that use it, they will be able to help.
Again welcome
Thank You John
Semipro is offline
post #3 of 16 (permalink) Old 07-07-2014, 01:28 AM Thread Starter
Thank you!
smg119 is offline
post #4 of 16 (permalink) Old 07-07-2014, 02:59 AM
Hi N/a. welcome to the forum.
If that happens with any variable speed router, it may indicate a faulty speed controller.
As the router is new, I would take it back to the store for checking.
Sydney, Australia
jw2170 is offline
post #5 of 16 (permalink) Old 07-07-2014, 07:29 AM
kywoodchopper's Avatar
First Name: malcolm
I take it you have checked to make sure the router is screwed into the mounting plate securely. Remove the bit and try a different bit if you have one to see if you still have the noise. Malcolm / Kentucky USA
kywoodchopper is offline
post #6 of 16 (permalink) Old 07-07-2014, 08:43 AM
First Name: Duane
Table Mounted? If not, probably a good idea for that bit.
Too deep of cut. Make cut in several shallow passes.
Only bit you are having trouble with? Possible bad bit.
Feed direction?
Then if all else fails, possibly a bad speed controller in the router, but I'd think that to be somewhat unlikely. Possible though.
Dmeadows is offline
post #7 of 16 (permalink) Old 07-07-2014, 09:05 AM Thread Starter
It does it with other bits as well and yes it is table mounted. It starts out running fine for about 1 min and then it goes into vibrating mode where it makes a ru-ru-ru-ru-ru-ru sound like a engine maxed out with the rev limiter on. Its brand new only used a couple times but did it from very start. I called Triton today and they will be calling me back. I kinda hope it's the speed controller because that's an easy fix. Thank you all for your quick responses I appreciate it.
smg119 is offline
post #8 of 16 (permalink) Old 07-07-2014, 09:14 AM
First Name: Don
Check it on another circuit see if it does the same thing, may not be enough amps.
Making sawdust & scraps all at the same time
Salty Dawg is offline
post #9 of 16 (permalink) Old 07-07-2014, 09:56 AM Thread Starter
Ill give it a try and let you know. Thanks.
smg119 is offline
post #10 of 16 (permalink) Old 07-07-2014, 10:54 AM Thread Starter
No go still doing it. It's weird because when I take the router out of the table it doesn't do it. When I put it back in the router table it takes about 2min and it starts its vibrating. I'm kinda leading towards the speed control. I wont take up anymore time because I could keep this thread going for a very long time. Thanks everybody for your time and help. I'm just glad I signed up with the router forum. And if I cant get this Triton to work ill just have to switch brands which would be a bummer. thanks again.
smg119 is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Triton router problem malang New Member Introductions 17 07-24-2013 02:34 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
