help with where to find small diameter polyethlene for hobby work - Router Forums
post #1 of 12 (permalink) Old 07-20-2014, 04:33 PM Thread Starter
Default help with where to find small diameter polyethlene for hobby work
Hi Folks, tryin to find out where to get polyethlene tube to make bushings for whirlygigs i have used brass on brass but want to get better weather performance thanks for any info mike
mike652 is offline
post #2 of 12 (permalink) Old 07-20-2014, 04:48 PM
kp91's Avatar
First Name: Doug
try searching for the company "TAP Plastics"
http://www.tapplastics.com/product/p...s_tubes_shapes
You will also be impressed what you find for sale on ebay.
Also look for Black Delrin or Nylatron as other good bushing options to make your own.
https://www.interstateplastics.com/a...FUcV7Aod_UAARA
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 12 (permalink) Old 07-20-2014, 07:13 PM
old55's Avatar
First Name: Ross
Welcome to the forum Mike.
Ross,
old55 is offline
post #4 of 12 (permalink) Old 07-20-2014, 08:19 PM
Two sources for poly tubing are aquarium shops and model aircraft hobby shops.
Make sure you have lots of spare time; it flies in these places!
The R/C model hobby shops will have stuff you didn't even know existed.
DaninVan is offline
post #5 of 12 (permalink) Old 07-20-2014, 08:49 PM
Lowes sells all manner of Black Delrin and Nylatron bushings in their hardware department..
they are in the drawered cabinets..
post #6 of 12 (permalink) Old 07-20-2014, 10:41 PM
Gaffboat's Avatar
First Name: Oliver
+1 with Stick's suggestion. I use the nylon bushings from Lowe's in a lot of my projects. They worked especially well for my recent Engineers Change a Lightbulb project as well as the Swamp Shakedown project.
The are available in several diameters and thicknesses. I used bushings that were 1/4" ID and about 1/4" thick to support the gears on the lightbulb machine gears and ones that were 1/8" thick as bearings for the hand crank supports. I find they create less drag than the metal washers. I highly recommend them.
Gaffboat is offline
post #7 of 12 (permalink) Old 07-20-2014, 10:48 PM
you can find load, spring, friction washers, grommets, sleeves and bearings in tube and shouldered there too...
post #8 of 12 (permalink) Old 07-21-2014, 06:27 AM
Enco has acetal rod in sizes of 1/4 inby 36 in and up in sizes. This is made for bearing use. You drill the size hole you need.
watsonwoodworking is offline
post #9 of 12 (permalink) Old 07-21-2014, 07:46 AM
Roefa's Avatar
First Name: Roger
Send a message via Yahoo to Roefa
All sorts of plastic bushings and bearings... no minimum order.
igus® iglide® plastic bearings from igus®
Thinking outside the box? What box?
Roefa is offline
post #10 of 12 (permalink) Old 07-21-2014, 09:15 AM
First Name: russ
I just saw a you tube vid where a guy uses the body of old bic (or similar) pens.
Russ
russfranken is offline
Is a small or large diameter bit better? jham66 Router Bits - Types and Usage 23 04-16-2012 01:06 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Small diameter circles. NewMontanaWorkshop Jigs and Fixtures 26 12-17-2007 11:04 AM
Gifkins small cutter diameter S Bolton Jigs and Fixtures 17 11-29-2007 12:05 PM
Small diameter circles. NewMontanaWorkshop Portable Routing 11 10-05-2004 10:25 PM
