The Journey Begins - Router Forums
post #1 of 11 (permalink) Old 07-24-2014, 07:18 PM Thread Starter
Default The Journey Begins
Well, my woodworking journey has just begun. Since the first of the year, I have acquired a table saw and router table. I've finally got my workshop tools, etc. worked into my budget, and I should be able to outfit a fairly complete shop over the next year....which begs the question, where to begin?
Along with upcoming purchases for miter saws, hand routers, joiners, planers, sanders, band saw, etc., it's obvious that I need a whole lotta hand tools as well, and this is my question now. I want to add some planes to my little shop, possibly one a month until I get what I need, really all the necessary hand tools. My interest is in cabinetry and intricate box building. I want to build some high end custom boxes for vaping gear, finished like humidors, i.e., high end polishing. This is background for you.
So, regarding planes, I think I want to start with a low angle jack plane and I've been looking at Lie Nielsen and Lee Valley/Veritas. I know they are both very good. It seems like the Veritas has attachments for a number of their planes that the LN's do not have, like optional fences, etc., so I'm leaning that way, but I'm having a hard time deciding. I plan to stick with one brand to make blade swaps possible. Can you help me please?
Which would you choose for a line of planes, LN or Veritas? Thank you!
WizardLV is offline
post #2 of 11 (permalink) Old 07-24-2014, 07:19 PM Thread Starter
Any help will be appreciated.
WizardLV is offline
post #3 of 11 (permalink) Old 07-24-2014, 08:29 PM
Hi, Bill; I'm no authority on hand planes, I only use a block plane and a jack plane, neither of which are expensive models...the block is a Stanley.
From my perspective, living a ferry ride away from the Vancouver Lower Mainland, I tend to go with whomever gives me great online/telephone service. Lee Valley is a rock solid supplier, so for me that's what I need.
(...A plane a month?! You do know that you can resharpen the blades; you don't need to replace the plane... )
DaninVan is offline
post #4 of 11 (permalink) Old 07-24-2014, 08:49 PM Thread Starter
LOL, indeed I do know. A block plane, rabbit plane, smoothing plane, jointer plane, and perhaps a few specialty planes, among a few different blades and a few more setups. I don't have stones yet either, so I need those, as well.
WizardLV is offline
post #5 of 11 (permalink) Old 07-24-2014, 08:59 PM
MikeMa's Avatar
I own hand tools from both Lee Valley/Veritas and Lie-Nielsen. You won't go wrong with either choice. The big difference is Veritas has take a modern spin on hand tools where Lie-Nielsen tools are much more traditional.
My next hand plane purchase will likely be a LA Jack Plane as well, and I will likely go with the Lie-Nielsen version.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #6 of 11 (permalink) Old 07-24-2014, 09:34 PM
DaninVan is offline
post #7 of 11 (permalink) Old 07-24-2014, 10:24 PM Thread Starter
Default New Steel
Originally Posted by DaninVan View Post
I knew they had that steel, I just didn't know how different, perhaps advanced, it was. Thank you. Very interesting!
WizardLV is offline
post #8 of 11 (permalink) Old 07-25-2014, 10:12 AM
rwl7532's Avatar
First Name: Ralph
How big is the garage you intend to fill up with tools?
Do you have 240v available?
I have a one car garage and only one 120v outlet. I have to use one tool at a time or I run the danger of tripping the 20amp breaker. My profile lists my tools.
Until a few weeks ago, I was able to scoot all the tools to the sides and end and still park my Camry.
A two car garage with plenty of drawers and no intention of parking cars in it?
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #9 of 11 (permalink) Old 07-25-2014, 10:20 AM
Harry Hill's Avatar
First Name: Harry
Two types of hand planes to consider having in your tool inventory are the Router Plane (recommend both a large and a small plane) and the Side Rabbet Plane (recommend both a right hand and left hand version). These are extremely useful to shave just a slight amount of material off the bottom or side of a dado/tenon/rabbet, when the need will arise.
Wood is not always the exact same thickness as a router bit or dado blade that is used to cut the grooves. The depth of cut obtained is not always consistent across a wide panel due to slight swelling of material used. When a router bit or table saw blade is just shy of providing the proper depth or width of a cut for a mating piece to the dado/tenon/rabbet these Plane tools save a lot of frustration. To attempt re-cutting the dado/tenon/rabbet with the power tools can result in removing too much material thus creating slop in the joint; slop that may then need to be adjusted creating an unsightly repair.
I was making bookcases with shelves inset utilizing routed dados. The plywood was not a standard 3/4 inch thickness and the router bit was not an exact 3/4 inch (just my luck too). I purchased the LH/RH Side Rabbet Planes to remove the few thousandths of material thus allowing my dados to look crisp and just the right amount of tightness. While jigs would probably have helped, I did not have any at the time.
There were times a dado/rabbet was not deep enough in some areas of the grooves but was not detected until assembly of the wood components. The Router Plane helped to quickly correct the situation with exact accuracy throughout the groove.
Both Veritas and Lie-Nielsen sell these style of planes (I bought the Lie-Nielsen versions a long time ago when I attended a tool show in Seattle). They both have videos explaining their setup and use. There are also other instructional videos on YouTube covering these types of planes and their uses. I highly recommend watching any Router Plane videos to see the value in these planes. Here is one video, done by Highland Woodworking, as an example: Lie Nielsen Router Planes Product Tour - YouTube
All I can say is these planes have saved me a lot of frustration several times when I have ran up against the unexpected tolerances due to wood size/movement or tool design/setup inaccuracies. Just thinking about them brings me a feeling of relief (then again - I am a tool-addict so I may just be getting a slight high as I think about tools and look through the catalogs. *grin*)
I apologize for being so wordy. I tend to talk too much.
Harry H
Harry Hill is offline
post #10 of 11 (permalink) Old 07-25-2014, 01:12 PM Thread Starter
Yes, I have 240 already installed, and use it on my table saw. I plan to add a 240 100 amp subpanel as the need arises, and have pre-wired for this (home is semi-custom built for us).
I have a 2-1/2 car garage and plan to take it over (in time), and to the future dismay of the missus. I have spent countless hours on layouts and tool selection. I do have cabinets now, but plan to replace them all with customs, self-built for exact shop needs. The future design will allow for one car parking in the garage, but only when the shop is not being used. It's only a matter of time before the missus' Camaro refuses to enter the workshop.
WizardLV is offline
Moving to Florida Iceman567 Lobby 16 09-18-2013 08:02 PM
My Ellipse Poker Table Begins AzViper General Routing 0 07-13-2011 07:51 PM
Culmination of my journey gal turner Show N' Tell 35 08-20-2010 09:58 AM
