Best way to cut with a hole saw - Router Forums
post #1 of 35 (permalink) Old 07-26-2014, 12:37 AM Thread Starter
tak35bne's Avatar
First Name: Dave
Default Best way to cut with a hole saw
Ok so I want to cut 70mm diameter holes (10 of them) in a piece of nice timber (2 rows of 5) to make a top for a storage project for my fly rods in their tubes.
My first attempt with a hole saw in a hand held drill did not go all that well with splintering and mis-alignment.
The question is can a pedestal drill spin fast enough to cut with a hole saw?
tak35bne is offline
post #2 of 35 (permalink) Old 07-26-2014, 05:39 AM
Gene Howe's Avatar
First Name: Gene
Most pedestal drills today are capable of spinning a hole cutter of that size. That would be my first choice. A hand held, as you've found, can be problematic.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 35 (permalink) Old 07-26-2014, 05:46 AM
Hi Dave, I use my Ryobi drill press often with a hole cutter.
I usually don't have a problem.
Sydney, Australia
jw2170 is offline
post #4 of 35 (permalink) Old 07-26-2014, 05:52 AM
yes, a drill press will work...
have you considered a 70mm forstner bit???
Stick486 is offline
post #5 of 35 (permalink) Old 07-26-2014, 06:04 AM Thread Starter
tak35bne's Avatar
First Name: Dave
I will have to have a look to determine what a forstner bit is......
tak35bne is offline
post #6 of 35 (permalink) Old 07-26-2014, 06:12 AM Thread Starter
tak35bne's Avatar
First Name: Dave
I now know what a Forstner Bit is............am now on the hunt for a suitable size, cheers
tak35bne is offline
post #7 of 35 (permalink) Old 07-26-2014, 06:54 AM
paduke's Avatar
To free hand with a hole saw ... Low RPM start the mandrel Before the saw touches Stop and visually align the saw with the surface. tap the trigger a few times and adjust drill posiition while watching the saw do its initial cuts
To avoid burning. After starting the hole saw, drill 2 clean out holes inside the circle with with a twist drill bit. This will allow the saw dust to drop away from saw teeth and reduce burning. Sometimes I mark hole center on both sides of the work and start the hole cut on both sides before finishing in the middle. This prevents splintering when the bit breaks through the far side.
paduke is offline
post #8 of 35 (permalink) Old 07-26-2014, 07:13 AM Thread Starter
tak35bne's Avatar
First Name: Dave
Thanks for that, I broke my drill press this arvo when trying to use the hole saw. I made sure the arbor was tight into the chuck and when I started the cut I went very very gently and as the hole saw started into the timber it grabbed which separated the hole saw & arbor AND the chuck from the drill press.
tak35bne is offline
post #9 of 35 (permalink) Old 07-26-2014, 07:30 AM
dry lube also helps..
Stick486 is offline
post #10 of 35 (permalink) Old 07-26-2014, 08:23 AM
Dave most drill press chucks are attached to a tapered arbor. It is meant to form a friction fit connection with the drill head of the machine. If you've ever heard of a Jacob's or Morse tapers your press likely has one of the several tapers that are available. Clean the arbor with a clean rag and the inside of the drill spindle. If there is any varnish or foreign looking substance on it that isn't coming off try mineral spirits. Then put the chuck back in the machine without anything in it and press down hard on a scrap board. Hopefully this procedure will lock the chuck back into the spindle. Machine taper - Wikipedia, the free encyclopedia
Like Stick, I recommend using a Forstner bit. It should do a better job and be easier to use.
up cut vs dn cut? tvman44 Router Bits - Types and Usage 6 07-10-2013 06:08 AM
How Does One Make Face Bevel Cut In Drawer Face For Standup Desk? tkleff General Routing 10 02-28-2013 01:15 AM
Beginner Question: Should/Could I use a template to cut a hole like this? dbishopbliss Guide Bushings and Templates 9 08-10-2012 02:16 PM
How do I cut 3 ½” dia hole? JohnnyB60 General Routing 43 05-07-2012 10:35 AM
Square Peg in Round Hole? Gato9 Table-mounted Routing 2 12-15-2011 09:33 AM
