Using a router freehand - Router Forums
post #1 of 4 (permalink) Old 08-05-2014, 04:27 AM Thread Starter
tak35bne's Avatar
First Name: Dave
Default Using a router freehand
Ok so I have an additional project to look at. I want to make a mate of mine a fly tying bench for his birthday, making the bench is not the issue, what is the issue is at the front of the bench I want to cut a recess into the base of the bench to take the pedestal base of the fly tying vise. In the attached image you can see the recess and I was hoping the members here could give me some advise on how to do this.
I have a router set up in a table but I also have a router I can use freehand. Looking forward to your advice.
tak35bne is offline
post #2 of 4 (permalink) Old 08-05-2014, 05:50 AM
Don't know how to say this, Dave, but you need another router.
I have found that I use my routers free hand more that in the table.
I believe you have a Triton in the table? This should be easy to remove and re-insert the spring to use free hand as needed.
Others may have different experience.
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 08-05-2014, 09:44 AM
Dave, one of the reasons we encourage members to list the equipment and experience they have is so that we can tailor the advice we give. It seems I remember Harry or James saying once before that most routers sold down under are plunges? If that's the case then follow James advice. You can make a template to follow. If you use a pattern bit to cut the recess then you can make the template the same size as the vise base.
post #4 of 4 (permalink) Old 08-05-2014, 12:27 PM Thread Starter
tak35bne's Avatar
First Name: Dave
Good advice Charles, I have listed the equipment I have, The Triton plunge router is mated with the table, I have a Bosch plunge router to use freehand.
tak35bne is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
freehand router use answrtek Starting Off 8 09-12-2012 02:45 AM
