Can phenolic plywood destroy my saw? - Router Forums
post #1 of 19 (permalink) Old 08-14-2014, 05:08 PM Thread Starter
Country: Argentina
First Name: Pablo
Default Can phenolic plywood destroy my saw?
Hi, given the place I live, we don't have here "plywood", or at least is not common.
However, something we have, is "phenolic".
AFAIK, it's actually phenolic plywood.
However, the places I went to buy the wood they said that they don't cut it, since it destroy they saws. All other woods they do cut them, like MDF, pine, etc, every other one except this phenolic plywood.
So, my question is, if it destroy their saws, maybe it does the same with mine?.
Thanks!.
Artemix is offline
post #2 of 19 (permalink) Old 08-14-2014, 05:41 PM
Thanks!.
not the saw - the cutters/blades...
go back to the manufacturer and ask them what style/type of blade they use to cut their own product...
post #3 of 19 (permalink) Old 08-14-2014, 07:25 PM Thread Starter
Country: Argentina
First Name: Pablo
Yeah I meant the blade, my bad.
I will ask the manufacturers what they use to cut it then.
Thanks.
Artemix is offline
post #4 of 19 (permalink) Old 08-14-2014, 07:41 PM
Thanks.
look to a TCG blade with a low to negative hook angle......
post #5 of 19 (permalink) Old 08-14-2014, 11:27 PM
RainMan 2.0's Avatar
Thanks!.
You had me concerned there for a second lol. Sounds like it must be tough on blades though .
Other than a fine tooth carbide blade what the heck else is there? If that's the case it must dull router blades in a hurry to . I was interested in using this material at one time myself so very curious
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 19 (permalink) Old 08-15-2014, 12:14 AM
If it's the same stuff..
here it's called NorFormFir or Burke-ply..
used for reusable concrete forms...
and it will destroy cutters...
we cut with a circular saw and demo blades...
by the 10 pack..
Artemix, can you link us to that plywood???
wonder if this one would work..
Freud Tools | 8" Plastic Blade
Freud Tools | 10" Plastic Blade
post #7 of 19 (permalink) Old 08-15-2014, 08:38 AM
John Bradshaw's Avatar
Your education of my mind is getting bigger every day. Thank you.
John Bradshaw is offline
post #8 of 19 (permalink) Old 08-15-2014, 09:13 AM
Garyk's Avatar
First Name: Gary
I've cut a limited amount of phenolic plywood with my Forrest Woodworker blade and did not notice any issues with the blade after the project. However, it stands to reason that using wood cutting blades for other, harder, materials will eventually dull the blade. I'm with Stick on this one. Buy a pack of cheap blades, make the cut and throw the blades away.
Garyk is offline
post #9 of 19 (permalink) Old 08-15-2014, 05:56 PM Thread Starter
Country: Argentina
First Name: Pablo
by the 10 pack..
Yes, here are two links of companies that offer that product:
Placa de Fenolico 18mm 1,22 x 2,44 mts Grandis Industrial
and
Grandis | todofenolicos
Not sure how much info can be obtained from there though.
Artemix is offline
post #10 of 19 (permalink) Old 08-15-2014, 06:23 PM
and
we have your Grands here...
I know that ply...
be right back....
okay...
is the ply you have only faced or phenolic layered???
use the TCG blade with about a 5º hook angle if it's only faced..
use the polycarbonate blade if it's phenolic all the way through...
raise the blade around 35 to 40MM above the ply...
push the ply through the saw at a steady rate(you'll know if you are going too fast and don't stop or pause... avoid going really slow...
http://www.plywoodsuppliers.net/ligh...sheet-p-6.html
Phenolic plywood Kensway Tools and Woodworking 0 01-13-2012 04:45 AM
phenolic plywood jsjcarp Lobby 1 09-01-2011 02:33 PM
Best method to band plywood without tear out Slomoe Router Bits - Types and Usage 8 02-26-2011 10:06 AM
Phenolic Finnland Birch Plywood TwoSkies57 The Bargain Bin 1 05-08-2010 08:44 AM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
