Larger boards??? - Router Forums
post #1 of 8 (permalink) Old 08-15-2014, 08:53 AM Thread Starter
Default Larger boards???
retired NYC union carpenter who worked installing woodwork started in shop then in the field………..have some air dried cherry from my property…moisture is about 5 to 7% having trouble mating the edges straight and getting the cup out of my boards, should i try working with narrow boards ,say 3 or 4 "?
cptjack is offline
post #2 of 8 (permalink) Old 08-17-2014, 11:00 PM
MAFoElffen's Avatar
Yes... Many times boards over 4" wide boards in glue-ups... and it has bitten me in the behind. I usually do my glue-ups with 2-3" wide boards. More luck with that.
I still chance it every once in a while, It well dried and if I really like the pieces, the grain and knurling... But I know before I start that that risk is there.
MAFoElffen is offline
post #3 of 8 (permalink) Old 08-17-2014, 11:10 PM
cupping sounds like flat sawn wood...
narrow rips it is...
Cup Defect
Rip a wide, cupped board into narrow flat sections.... Rip each piece slightly wider than you need, then re-rip or joint the edges square to the face. You even can glue these sections back together to create a wide board...
File Type: pdf CHARACTERISTICS OF WOOD and DEALING WITH THEM.pdf (485.9 KB, 39 views)
post #4 of 8 (permalink) Old 08-17-2014, 11:15 PM
Semipro's Avatar
First Name: John_*
Hey it's great to meet you and have you as a member of our community, welcome!
Thank You John
Semipro is online now
post #5 of 8 (permalink) Old 08-17-2014, 11:40 PM
RainMan 2.0's Avatar
Welcome to the forum Jack
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 8 (permalink) Old 08-18-2014, 12:36 AM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #7 of 8 (permalink) Old 08-18-2014, 06:41 AM Thread Starter
thanks guys
cptjack is offline
post #8 of 8 (permalink) Old 08-18-2014, 06:15 PM
brille's Avatar
Country: Germany
First Name: Uwe
Thanks a lot for the informative PDF, Stick!
brille is offline
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 11:19 AM
Surfacing boards? tvman44 Sign Making 6 07-15-2014 11:12 AM
Planing with a Router Gilbear Portable Routing 51 05-17-2012 04:40 PM
First Cutting Boards Soapdish Show N' Tell 3 02-03-2010 10:35 AM
Jointing long boards Jtomwoods Table-mounted Routing 8 05-25-2008 09:05 PM
