Pro Tech Contractors saw adjustments - Router Forums
post #1 of 11 (permalink) Old 08-20-2014, 04:57 PM Thread Starter
Contributor of the Month
Bushwhacker's Avatar
First Name: David
Default Pro Tech Contractors saw adjustments
This is not directly a routing question, except that it causes a problem when I try to route Rail ends. My ProTech Contractors series Miter saw is not cutting a true angle cut, be it 45 or 90. Which throws my rail ends off. I can not find an adjustment to the saw angle. It locks at different setting. but they are all slightly off true. I can set it for true, and lock it down, but while using it, it will vibrate into the lock position slot and I don't know it until I attempt to fit two pieces. I have the table apart but can not find an adjustment to it. any help would be greatly appreciated.
Bushwhacker is offline
post #2 of 11 (permalink) Old 08-20-2014, 05:14 PM
old55's Avatar
First Name: Ross
David I am not able to help with your inquiry but I'm sure someone more knowledgeable than me will be along to help with your problem.
Ross,
old55 is online now
post #3 of 11 (permalink) Old 08-20-2014, 06:05 PM
RainMan 2.0's Avatar
I wish I could see a photo as my makita was not true either . I'm referring to turning the assembly on the table for a 45 or 90 , not bending the blade over .
The fence on my saw has bolts and I loosened them and moved the fence itself till I got a true 90 . Sorry if yours is different
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 11 (permalink) Old 08-21-2014, 10:14 AM
First Name: Duane
I agree with Rick... loosen mounting bolts and align the fence true.
Dmeadows is offline
post #5 of 11 (permalink) Old 08-21-2014, 02:49 PM Thread Starter
First Name: David
Default Fence adjustment rather then adjusting the blade.
That sounds like a great idea. I'll check it out as soon as I finish a list of "Honey Dos".
post #6 of 11 (permalink) Old 08-21-2014, 02:50 PM Thread Starter
First Name: David
Default Fence adjustments.
I'll let you know if that works, thanks.
post #7 of 11 (permalink) Old 08-21-2014, 06:16 PM Thread Starter
First Name: David
Default Pro tech adjustments
Thanks for the suggestion Rick. I tried the Guide but it had 2 bolts on each side but only for removing it. I flipped the whole thing up side down ( after carefully pulling the plug). and there were two allen bolts under there that allow adjustments to the blade setting. Took a couple of trys to get it going in the right direction, but I seem to have gotten it get pretty good.
Thanks again for the help, your idea got me looking further.
David
:When the enemy is in range, so are you.
post #8 of 11 (permalink) Old 08-21-2014, 06:19 PM Thread Starter
First Name: David
Default Pro tech adjustements
Thanks for the help Duane. The adjustment bolts were under the saw. I found them by flipping the whole thing up side down. Took a couple of tries to get it going in the right direction, but it seems to be fine now. Thanks for the help.
David
When the enemy is in range, so are you...
post #9 of 11 (permalink) Old 08-21-2014, 06:38 PM Thread Starter
First Name: David
Thanks for jumping in there to help Ross. I finally got it figured out.
By the way, what part of Texas is Rockhampton in?
David
When the enemy is in range, so are you......
post #10 of 11 (permalink) Old 08-21-2014, 09:10 PM
Thumbs up
+2.. even works on my cheapie...
Sydney, Australia
jw2170 is offline
For Sale: CNC Shark Pro Routing System Henrymco Woodworking Classifieds 0 08-13-2012 05:01 PM
Shark, Shark PRO, Shark Pro Plus MisterG CNC Routing 6 10-05-2011 10:27 PM
Bench Dog Pro Plate and Zero Clearance Insert problem matt1710 Table-mounted Routing 24 07-17-2011 07:37 AM
Shark Pro Question-Planning on purchasing Ron.Jeanette General Routing 3 05-25-2010 08:44 AM
