Dust Collector Hose for Cleanup - Router Forums
post #1 of 19 (permalink) Old 09-03-2014, 09:39 AM Thread Starter
First Name: Doug
Default Dust Collector Hose for Cleanup
Does anybody reduce their dust collector down to a relatively small hose for general cleanup around the shop? I'm debating placing an overhead 4" port central in my small shop, to which I can attach a shop vac hose (1.5 or 2" diameter, 15' or so) to pick up misc sawdust that wasn't captured by the DC.
I'm looking at the Dustless Technologies hose and the Bosch hose on Amazon.
I'm just wondering if reducing the 4" down to 1.5-2" hose of any significant length will render the airflow useless.
FYI, I'm a newbie when it comes to DC. I'm just wrapping up a Harbor Freight setup with a Super Dust Deputy separator. I'm keeping ductwork simple... 2 x 4" ports... one for individual tool hookup (tablesaw and router are on wheels, SCMS will have dust collection box nearby) and the other for a floor sweep.
Thanks!
TheDougOut is offline
post #2 of 19 (permalink) Old 09-03-2014, 10:01 AM
DC's work better w/o a lot of reductions...
the last thing you want to do is use your DC as a shop vac...
all it's going to take is some metal hardware sucked up into the system and you now have a damaged impeller, holes in the collection bag letting more fines get loose, (talk about one step forward and three backwards) damaged hoses, sparks to ignite either the airborne fines or the sawdust it's self, cut filters... and the list goes on...
so ditch that floor pick up..
you evidently have never tried to put out a sawdust fire... sad part it will be well under way before you notice...
heard the arguments but experience rules...
they are convenient though..
Been there and done that...
give the shop vac something to do.. it's job...
all your finals appear to be open at the moment - why no gates...
w/o gates to shut off a lot of the free flow your DC will only show dismal results...
another thing...
make sure sawdust is kept out of your sump or you'll be buying another pump...
make a filter for it...
Stick486 is offline
post #3 of 19 (permalink) Old 09-03-2014, 10:49 AM Thread Starter
First Name: Doug
Thanks for the response!
The blast gates are located right off the main line, 3" down from the WYEs to minimize dead air behind whichever line is open. I have the end capped off for now with no blast gate.
Are heavier objects (metal) more likely to make it though the separator? I've only run some initial collections, and have emptied about 6" or so of material out of the collection can a couple times. With this initial testing, I've had nothing of substance make it to the impeller. My collection bag beneath the filter remains empty (I struggle to find evidence of fines). I see it two ways... if metal makes it to the impeller (which could cause heat/spark), the best place for it to end up is in the collection bag beneath the filter, as it's empty (I vote for hole in bag over fire trucks). If it doesn't make it to the impeller, is there any difference between metal ending up in a garbage can of sawdust vs. a shop vac full of sawdust?
I appreciate the info you're sharing, I'm just trying to fully understand. I've debated an alternative approach... mounting a shop vac and running a 2" pipe to a central location.
Good thinking on the sump pump cover... I'll need to come up with a way to seal the holes.
Thanks again!
post #4 of 19 (permalink) Old 09-03-2014, 11:38 AM
MT Stringer's Avatar
I have the Bosch VAC005 hose. When connected to a 4 inch port via adapter, the suction is reduced quiet a bit, but it still works for cleaning up sawdust.
Thank goodness for a separator. It finds all of the little things I drop like screws or nuts that just seem to disappear! :-)
MT Stringer is offline
post #5 of 19 (permalink) Old 09-03-2014, 11:38 AM
sorry.. missed that...
No, but smaller chips will and when they tangle w/ the impeller sparks and hot metal flakes are produced...
look inside of the filter...
[B]pretty much the same... but why tempt fate or invite Murphy into the shop..
w/ a shop vac nothing ever tangles with the impeller...[B]
I appreciate the info you're sharing, I'm just trying to fully understand. I've debated an alternative approach... mounting a shop vac and running a 2" pipe to a central location. (domestic vac system)
after all these years of playing around to include a serious domestic vac... (the pipe plugging up defeated the system)... the wheeled shop vac w/ a quality smooth bore 12' hose (got it from a janitorial supply house) and assorted nozzles/sweeps won out - again... a big plus was the offset handle that fits the hose
a larger than the lid metal framed reinforced HVAC filter pinned/clamped to the floor..
water gets through and the sawdust doesn't
Here's what I have on DC systems...
File Type: pdf D.I.Y. Dust Collection - Installing your Dust System.pdf (67.6 KB, 67 views)
File Type: pdf Installing your air handling system.pdf (281.8 KB, 96 views)
Stick486 is offline
post #6 of 19 (permalink) Old 09-03-2014, 01:00 PM
RainMan 2.0's Avatar
My Festool hose connected to my GI dust collector refuses the flow by a lot . Wouldn't recommend .
Dust right makes a system to keep the size to a 4 inch , but there's the risk of sucking something metal into the impellers . Personally I would build a screen to stop screw drivers etc from possibly being sucked into the system
http://www.rockler.com/dust-right-master-system
Ok ,I never insulate
RainMan 2.0 is online now
post #7 of 19 (permalink) Old 09-03-2014, 01:35 PM
how would a screen work???
wouldn't catch the chips and sawdust too???
Stick486 is offline
post #8 of 19 (permalink) Old 09-03-2014, 02:05 PM
When you reduce a 4" down you increase the velocity at the opening but overall airflow is reduced. Once it opens up to 4" velocity drops below what you would have if it had a 4" opening which means some of the debris in the flow may not stay suspended.
post #9 of 19 (permalink) Old 09-03-2014, 02:24 PM
By looking at his picture, I feel sure that all but the tiniest dust particles will drop out into the can below his cyclone.
post #10 of 19 (permalink) Old 09-03-2014, 02:36 PM
tvman44's Avatar
First Name: Bob
I have a 4" blast gate at my work bench to connect my router to and also connect a 2 1/2" shop vac hose for clean up. Does not have near the suction of my shop vac but does the job & I don't have to start dragging out the shop vac for clean up.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
Index of Dust Collection Solutions and Comments allthunbs Shop Safety 28 03-14-2014 01:40 AM
My Dust Collection System MAFoElffen Tools and Woodworking 19 05-23-2013 03:39 PM
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 01:51 AM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 02:32 PM
Dust Collection Question Tigerpaw Table-mounted Routing 17 04-16-2009 04:42 PM
