Homemade micro jig gripper? - Router Forums
post #1 of 29 (permalink) Old 09-07-2014, 09:33 AM Thread Starter
Country: Argentina
First Name: Pablo
Default Homemade micro jig gripper?
Hi, after so many fail attempts at trying to bevel cut a thing piece of wood I've realized something, I need to have some kind of better push/pressure system to make it work.
Even when the cut is ok, the edge is not.. perfect, it's full of blade marks, which means that I couldn't maintain a full and constant pressure all the time of the piece of wood against the fence (correct if I'm wrong).
So, I watched some videos of the micro jig gripper and it seems.. amazing.
But, there is one problem, the product is impossible to get where I live. Not even if I want to buy it, plus the shipping, plus the customs tax I will be able to acquire one.
That leaves me with one alternative, to make one.
I was googling for some time, but it seems like not many people tried to make one, I've only found one link that only contain some images.. well.
Do you guys have any info about how to build one?.
Thanks!.
Artemix is offline
post #2 of 29 (permalink) Old 09-07-2014, 02:18 PM
paduke's Avatar
A sled that holds the piece you are cutting is easier to build
paduke is offline
post #3 of 29 (permalink) Old 09-07-2014, 02:55 PM Thread Starter
Country: Argentina
First Name: Pablo
I see, would that be your approach to cut a bevel in a long piece of MDF for example?.
Artemix is offline
post #4 of 29 (permalink) Old 09-07-2014, 03:05 PM
First Name: Phillip
There was a fellow about a year ago who posted pictures of one he had made. If you try a few search box keywords, you might find it. If you have any access to ready-made hardware such as angle iron the task might be easier and a bit more professional. You might consider making the custom features from composite materials like MDF that won't move too much over time.
To change the world, change your mind.
phillipdanbury is offline
post #5 of 29 (permalink) Old 09-07-2014, 03:21 PM
how long???
how wide???
Stick486 is offline
post #6 of 29 (permalink) Old 09-07-2014, 03:41 PM
these work to hold the material down and against the fence...
Stick486 is offline
post #7 of 29 (permalink) Old 09-07-2014, 03:43 PM
rip to near size and finish w/ a straight edge and router...
Stick486 is offline
post #8 of 29 (permalink) Old 09-07-2014, 03:46 PM Thread Starter
Country: Argentina
First Name: Pablo
But I need a 45 degree angle, do you mean that I should tilt the router?.
I also looked for long 45 degrees or "v" shape bits but I couldn't find a long enough one.
Artemix is offline
post #9 of 29 (permalink) Old 09-07-2014, 03:58 PM
you mean this???
Stick486 is offline
post #10 of 29 (permalink) Old 09-07-2014, 04:00 PM
another...
Stick486 is offline
Simple homemade dovetail jig g-man Jigs and Fixtures 20 06-03-2013 10:04 AM
Jig Fabrication Tony1012 Jigs and Fixtures 2 03-31-2011 08:21 PM
Anyone use/have the Kehoe Dovetail Spline Jig? thewoodennewfie Jigs and Fixtures 70 04-26-2010 06:26 AM
Homemade dovetail jig Clint Mason Jigs and Fixtures 4 01-20-2009 09:52 PM
Homemade dovetail jig? islandboy Table-mounted Routing 1 01-20-2008 06:34 PM
