Random orbital vs Orbital sander - Router Forums
post #1 of 7 (permalink) Old 09-17-2014, 10:23 AM Thread Starter
Default Random orbital vs Orbital sander
I'm currently using a 125mm dia Makita random orbital and although the results are good it does take quite a long time when sanding out scratches on full 8x4 veneered sheets on both sides with 180grit. I've seen a few sheet orbital sanders that have 3x the sanding sheet size but they are all non-random.
If I use a palm sander I end up with swirl marks that turn up after I've applied the final wax-oil finish; it's even more evident with the walnut veneers.
Do sheet orbital sanders leave swirl marks with 180-grits, and does having a more powerful sander with a large sheet sand quicker than a small ROS?
Baller is offline
post #2 of 7 (permalink) Old 09-17-2014, 11:33 AM
MAFoElffen's Avatar
(Welcome to the forum.)
Yes, they will--> but any type of orbital or radial sander will with 180 grit. 180 grit is fairly rough and is not a finish grit. After a 180 grit, then go over with 240 then 320 grits.
With veneers, then are already smooth, depending how they look, I start out with 320 or 240 grit. It you start them out with 180 grit, you are going making them un-needily rougher than they are, just to try to get then smooth again-- then you also risk sanding them thin.
The reason this is true, and more noticeable over hand sanding or an old electric block sander, it that with those two methods, you sand with the grain. With the aforementioned sanders, you get some cross-grain sanding... which to hide, you really have to go smoother, to hide in the finish stage. It you just think basically, this may dissuade you from... But Orbitals do such a good good and are very fast. Personally, I don't like spending my time sanding... I would rather spend my time doing other things... So faster and better sanding by an orbital sander is a good thing.
If your eyes or feel cannot see swirls or scratches well, wipe your work with thinner, wood conditioner or a damp cloth and the sanding marks, scratches, etc, with be amplified while wet. Be sure to let dry before sanding again.
MAFoElffen is offline
post #3 of 7 (permalink) Old 09-17-2014, 06:19 PM
RJM60's Avatar
First Name: Robert
Default Why Such Big Pieces?
Just curious about sanding 4x8 sheets of veneer. What are you making that's so big and how are you gluing up such large pieces. Usually, sanding is done when pieces are close to the final size. Just asking ...
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #4 of 7 (permalink) Old 09-17-2014, 06:24 PM Thread Starter
So is a large and more powerful orbital better than a small random? Veneers need to be 180grit for me as I'm applying hard-wax oils — it doesn't absorb well if it's too smooth.
Baller is offline
post #5 of 7 (permalink) Old 09-17-2014, 06:30 PM Thread Starter
It's for large furniture items such as 8ft long media cabinets and wide sliding wardrobe doors. Due to the minimalist design I find it easier to sand & finish the sheets before cutting up and edge banding with only minor extra hard-wax oil application needed for the wood edge banding.
Baller is offline
post #6 of 7 (permalink) Old 09-17-2014, 06:47 PM Thread Starter
Problem solved: I've decided to just buy a more powerful Mirka ROS and fit a larger head.
Baller is offline
post #7 of 7 (permalink) Old 09-17-2014, 07:02 PM
MAFoElffen's Avatar
For that application and something that large, if you had the volume to justify it, I would have thought a drum-type thickness sander.
- Sanded in the direction of the grain.
- Consistent.
- No brainer type of skillset needed to setup and feed skins.
- You could fabricate your own for any width you need.
* So applying skins that large, you are probably using a vacuum clamp?
I Think I'm In The Market For A New Orbital Sander Jerry Bowen Tools and Woodworking 44 05-20-2016 03:13 PM
Random Orbital Sander vs Power Planer ebeard Tools and Woodworking 17 01-24-2011 09:33 PM
Bosch 3107 DVS 5" Random Orbital Sander rstermer Tool Reviews 5 06-15-2009 09:56 PM
