DC hoses... - Router Forums
post #1 of 7 (permalink) Old 09-19-2014, 10:10 AM Thread Starter
Default DC hoses...
After struggling for a while trying to get the wire reinforced vinyl hose ends on to ABS fittings and idea was struck...
Went and found several metal shoe horns held in place w/ a hose clamp....and used them to facilitate getting the hoses on to the fittings along with a wee bit watered down dish soap...
No muss no fuss.. The hose fittings slipped together so sweetly, as in right now...
Stick486 is offline
post #2 of 7 (permalink) Old 09-19-2014, 01:19 PM
First Name: Earl
Great tip!! At times after much struggle--I have (and know i shouldn't) been known to lick the fitting which helps a lot. But it's really hard to explain to my wife in any kind of reasonable manner--no need to ask how i know this.
earl
greenacres2 is offline
post #3 of 7 (permalink) Old 09-19-2014, 03:44 PM
Woodalyahave's Avatar
First Name: Chris
Nice tip Stick. I'll try this over licking any day!
Woodalyahave is offline
post #4 of 7 (permalink) Old 09-19-2014, 04:12 PM
First Name: Jerry
Stick,
Don't you know that the dimensions of these fittings are purposely designed to drive the user, in this case you Stick, crazy and cause you to use colorful adjectives about the way the fit just almost will fit but not quite fit until you have fussed with it for awhile.
You cheated by finding such a good way to get around the careful design of the manufacturer. Good for you.
Jerry
Jerry Bowen is offline
post #5 of 7 (permalink) Old 09-19-2014, 06:27 PM Thread Starter
Originally Posted by Jerry Bowen View Post
Stick,
Jerry
either the hose is undersized or the fitting is over sized and they are intended to fit together very tightly...
the better the hose the tighter the fit the tougher it is to get them fitted together...
this goes for the screw on fittings as well...
used the offset curved shape of 4 shoe horns (that's why the hose clamp to hold them in place) to form a funnel/ramp for the hose to slide up on the fitting...
once the hose was fully on the fitting I removed the horns and finished sliding the hose all the way on...
this is where the lube did it's thing...
FWIW, I use commercial smooth interior wall hose w/ metal windings......
Stick486 is offline
post #6 of 7 (permalink) Old 09-19-2014, 07:05 PM
First Name: Jerry
I'm pretty sure that the hose is under sized Stick.
post #7 of 7 (permalink) Old 09-19-2014, 08:11 PM
First Name: Clay
I usually sand the end of the pipe then use a heat gun to warm the hose, helps some, but it is still hard to get it on PVC
fire65 is offline
Down the DC Hole... or DC Project Part II MAFoElffen Tools and Woodworking 45 01-20-2017 10:37 PM
adapt a vacuum cleaner for shop use with the router loninappleton Jigs and Fixtures 25 05-24-2011 10:03 AM
Where do you find 1.25" hoses for a GripVac? (Porter Cable 891) JavaGeek Portable Routing 8 12-30-2010 04:30 PM
Vacuum extension hoses for a router loninappleton General Routing 22 08-26-2010 09:19 AM
what is better then a shop vac Glenmore Tools and Woodworking 22 11-17-2007 10:11 PM
