How would you clamp this? - Router Forums
post #1 of 42 (permalink) Old 09-19-2014, 07:22 PM Thread Starter
Country: Argentina
First Name: Pablo
Default How would you clamp this?
So, I got these two mitered pieces that I'd like to clamp somehow, and I've found out that it's not that simple.
If I apply pressure on the horizontal piece of wood, it wants to push the vertical one, same happens with the vertical one, using C-clamps, bar-clamps, etc. doesn't seem to work.
Something I did was just to not use any clamps, because the area of glue is so big that it doesn't seem necessary to clamp it.
However, I'd like to hear the experts opinion!.
Thanks.
Artemix is offline
post #2 of 42 (permalink) Old 09-19-2014, 08:10 PM
Thanks.
make several ""V"" blocks... save the cutout...
lay a piece of wax paper inside of the V blocks...
set the glued parts in the V blocks...
add wax paper to the inside of the glue up...
lay the waste block inside of the glue up on top of the wax paper...
use rubber bands as clamps to hold the whole V block/glue up together...
you have one of these in your future... invaluable...
23 Gauge | Cadex Tools
Grex Power Tools - Grex P6 Series 23 Gauge Headless Pinners
post #3 of 42 (permalink) Old 09-19-2014, 08:16 PM Thread Starter
Country: Argentina
First Name: Pablo
That seems like a good idea, I will give it a try.
About that 23 gauge tool, I never saw that before, I'll google it. Thanks.
Artemix is offline
post #4 of 42 (permalink) Old 09-19-2014, 08:19 PM
About that 23 gage tool, I never saw that before, I'll google it. Thanks.
I have both brands.. bullet proof...
you saw that kerf in the bottom of the V block... put one in yours...
clip the point of the waste block too...
post #5 of 42 (permalink) Old 09-19-2014, 08:22 PM Thread Starter
Country: Argentina
First Name: Pablo
Those are nailers right?, do you mean that I could use one of those for this?.
Artemix is offline
post #6 of 42 (permalink) Old 09-19-2014, 08:33 PM
pins, not nails...
it goes pin, brad, nail, spike....
certainly...
they shoot fine wire pins (.57MM dia.) 5/8 to 2" long... (1.5-5CM)
they will more than suffice as clamps for this project...
post #7 of 42 (permalink) Old 09-19-2014, 08:54 PM Thread Starter
Country: Argentina
First Name: Pablo
Alright, you mean something like this: (be aware my artistic skills can trigger deep emotions on the audience)
Artemix is offline
post #8 of 42 (permalink) Old 09-19-2014, 08:59 PM
correct...
make the V deeper and only as wide as it takes to get the job done...
what is your name...
as as often as we get together it'd be nice to know who's buying the beer...
post #9 of 42 (permalink) Old 09-19-2014, 09:01 PM
what would those be???
post #10 of 42 (permalink) Old 09-19-2014, 09:09 PM Thread Starter
Country: Argentina
First Name: Pablo
correct...
Pablo.
Artemix is offline
Kelly's New Router Jig Dejure Jigs and Fixtures 1 01-19-2014 12:09 AM
Extend Your Clamp Reach gmercer_48083 Project Plans and How To 10 08-26-2013 09:21 AM
1-Inch Pipe Clamp Fixture soltc Jigs and Fixtures 6 06-14-2012 10:25 AM
Clamp storage idea matt1710 Tools and Woodworking 6 11-16-2011 01:52 PM
Built in book shelf/ Shopnotes Clamp rack fasttruck860 Show N' Tell 14 09-25-2009 10:40 PM
