Need Help Locating A Vise.... - Router Forums
post #1 of 9 (permalink) Old 09-23-2014, 04:10 PM Thread Starter
First Name: Jerry
Default Need Help Locating A Vise....
I'd like to locate a relative inexpensive bench vise with a throat depth of four to five inches and jaws of no more than six inches. I have looked on line but so far no cigar, so I am just wondering if anybody knows where I might find such a vise.
Jerry
Jerry Bowen is offline
post #2 of 9 (permalink) Old 09-23-2014, 05:07 PM
JOAT's Avatar
First Name: Theo
Jerry
So, what do you call inexpensive? Metal working bench vise, or wood working bench vise? What search word/phrase did you use? How long did you look.? Because plenty easy to find stuff like that on-line. Or go to Sears.
JOAT is offline
post #3 of 9 (permalink) Old 09-23-2014, 06:11 PM
Check Lee Valleys vices Jerry. Not necessarily cheap but they won't disappoint. I have the twin screw end vide and it is the Cadillac of end vices but probably larger than you want.
post #4 of 9 (permalink) Old 09-23-2014, 06:21 PM Thread Starter
First Name: Jerry
I'm talking about a woodworking vise for under a hundred dollars. My present bench vise is one that I bought from Rockler for about fifty dollars, but its' throat is not deep enough for what I have in mind.
Thanks Theo,
Jerry
post #5 of 9 (permalink) Old 09-23-2014, 06:41 PM Thread Starter
First Name: Jerry
Check Lee Valleys vices Jerry. Not necessarily cheap but they won't disappoint. I have the twin screw end vide and it is the Cadillac of end buses but probably larger than you want.
Charles,
I don't see what I'm look for at Lee Valley. Actually it may not be a vise that I'm looking for. I am making a jig for cutting recesses in the edges of small boxes. The design is such that opposing recesses are cut with while both the lid and the carcass are clamped in the jig. Consequently the clamping needs to be done from what would be the bottom of the box. This is getting complicated as to how to describe. If the bos for example is three inches from the bottom to where the cut where the lid begins the vise or clamping device need to be such that the jig can be clamped from the bottom, thus the need to have a vise with a deep throat would be the best bet. If I can't find a vise I'll have to devise another way to clamp things up while routing out the recesses.
Jerry
post #6 of 9 (permalink) Old 09-23-2014, 07:26 PM
lenh's Avatar
First Name: Len
Charles,
Jerry
Can you show us a picture? If you are trying to rout a small recess where the side of the lid and the side of the box meet just tape the box together and use you router table. Is this possibly a shallow v groove in the back of the box for the barrel of the hinges? Guessing game.
lenh is offline
post #7 of 9 (permalink) Old 09-23-2014, 07:28 PM
You probably need a twin screw wood vise, Jerry.
The work can reach to the floor if required.
Sydney, Australia
jw2170 is offline
post #8 of 9 (permalink) Old 09-24-2014, 06:21 AM Thread Starter
First Name: Jerry
The jig is not ready for photos yet, it's mostly in my head in the design stage. The hinges will not be attached on the back of the box, but on the edges so that the leafs are hidden with the lid is closed with only the barrel visible from the rear. I certainly will send photos if and when the jig to work in the manner that I see it in my mind.
I have build three jigs so far and each time I see ways to improve it, R&D on such ideas provide me with much enjoyment.
Jerry
post #9 of 9 (permalink) Old 09-24-2014, 06:46 AM
Woodworking Vises, Bench Vises, Carving & Wood Vise at Woodcraft
Stick486 is offline
I'm in need of a drill press vise IC31 Tools and Woodworking 11 08-05-2013 12:26 PM
Woodworking vise advice volunteers Tools and Woodworking 3 05-29-2011 10:14 PM
Cross Slide Vise for Benchtop Mortiser Michael H Tools and Woodworking 29 10-21-2009 09:27 AM
mounting a light duty vise question... reikimaster Tools and Woodworking 9 09-20-2007 01:42 PM
