jerry's Next Quesion - Router Forums
post #1 of 3 (permalink) Old 10-09-2014, 12:54 PM Thread Starter
First Name: Jerry
Default jerry's Next Quesion
Is it just me or does anyone that uses a miter lock bit have trouble making a cut on end grain. I do have a zero clearance fence installed. This morning I was trying to cut end grain in walnut that was .400" thick but only about 2.5" inches wide so the length of the cut is short. I am wondering about making the cuts on wider, not thicker, stock so that the cut is longer, maybe easier to control, then if the cut comes out alright, then rip the piece to the desired width. My set up is correct I'm pretty sure.
Just, as I said, is it just me?
Jerry B.
Jerry Bowen is offline
post #2 of 3 (permalink) Old 10-09-2014, 02:05 PM
Gene Howe's Avatar
First Name: Gene
Jerry, using a wider board and ripping it to width is the best approach. I tried to use a pusher block and was successful but, it was scary trying to hold everything tight. So, now I use a double width + a saw kerf and then I have two pieces. A good thing when making drawer boxes.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 3 (permalink) Old 10-09-2014, 02:22 PM Thread Starter
First Name: Jerry
Gene,
You are verifying my thinking, I might not be as stingy as you and allow more that the kerf of the blade for my trim to size, I'll let you know after I try it. Thanks.
Jerry B.
Jerry's Defense Of His Posts Jerry Bowen Tools and Woodworking 31 11-12-2016 05:56 PM
Jerry's Latest Project Jerry Bowen Tools and Woodworking 21 11-01-2014 04:05 PM
Jerry's Latest Question Jerry Bowen Tools and Woodworking 21 02-09-2013 06:53 PM
Jerry's First M&T Joint... Jerry Bowen Tools and Woodworking 10 01-30-2013 02:46 PM
Jerry's latest Accuracy Test.... Jerry Bowen Tools and Woodworking 25 11-05-2012 07:01 PM
