What do you think of this technique? - Router Forums
post #1 of 10 (permalink) Old 10-12-2014, 09:03 PM Thread Starter
Country: Argentina
First Name: Pablo
Default What do you think of this technique?
I was searching for a way to make semicircular grooves and I found this video:
https://www.youtube.com/watch?v=nM73jNHY5A0
It seems like a clever idea of making it.
What do you think about it?, the only problem I see is that it could be prone to kickbacks, and that your hand is too close to the saw at some points, but it seems to work.
(he's speaking in Spanish, doesn't matter if you don't understand, just skip to ~2 mins.
Artemix is offline
post #2 of 10 (permalink) Old 10-12-2014, 09:27 PM
What do you think about it?, the only problem I see is that it could be prone to kickbacks, and that your hand is too close to the saw at some points, but it seems to work..
look to the cove molding videos...
https://www.youtube.com/results?sear...n+a+table+saw+
post #3 of 10 (permalink) Old 10-12-2014, 11:17 PM Thread Starter
Country: Argentina
First Name: Pablo
So thats how it's called, cove molding!, I will make some of those soon I hope I don't get kick-backed back to the forums .
Artemix is offline
post #4 of 10 (permalink) Old 10-12-2014, 11:27 PM
look to several of those videos and you'll see there are way safer ways to do it than the way your link shows...
post #5 of 10 (permalink) Old 10-12-2014, 11:53 PM Thread Starter
Country: Argentina
First Name: Pablo
Yeah, like having two guides instead of one, I thought so when I saw the video before.
Artemix is offline
post #6 of 10 (permalink) Old 10-12-2014, 11:55 PM
and hold downs and push blocks....
post #7 of 10 (permalink) Old 10-13-2014, 12:09 AM Thread Starter
Country: Argentina
First Name: Pablo
Yeah that too :P.
When I saw it I was like: "the moment he applies force in a wrong direction he will lose a couple of fingers".
Artemix is offline
post #8 of 10 (permalink) Old 10-13-2014, 06:43 AM
Country: South Africa
First Name: Denis
The technique for cutting coves on a table saw is well known. As mentioned by other posters there are much safer ways of doing it. The generally accepted way is to set the angled fences (use two and trap the workpiece between them) in their final position and start with the saw blade protruding a few mm above the table and to take multiple passes raising the saw blade on each pass. The final result requires a lot less sanding than shown in the video.
If my memory serves me correctly Rockler market a cove-cutting jig.
Denis Lock - Routing with Denis - Home
PS Somebody needs to tell the guy in the video about push blocks and push sticks.
denis.lock is offline
post #9 of 10 (permalink) Old 10-13-2014, 11:26 AM
RainMan 2.0's Avatar
I'm going to buy him push sticks for his birthday , if it's not to late lol
Ok ,I never insulate
RainMan 2.0 is offline
post #10 of 10 (permalink) Old 11-04-2014, 02:11 PM
First Name: Geoff
Default Cove cutting calculator and detailed information
Matthias Wandel at woodgears.ca has some very good information on this technique as well as a calculator to help you determine the setup you need for a particular cut.
I can't post URLs yet but lookup woodgears.ca
In the Shop Tricks section he has a link to his cove cutting information and calculator.
cylon58 is offline
Glue transfer technique Gaffboat Project Plans and How To 38 03-06-2015 08:52 AM
Template technique kingsuv Jigs and Fixtures 4 12-28-2012 08:36 PM
Routing Planes & Plow Planes - Technique & Setup wbh1963 Tools and Woodworking 0 03-26-2012 02:54 AM
