Drawbores for Breadboard Ends - Router Forums
post #1 of 6 (permalink) Old 10-22-2014, 11:06 AM Thread Starter
First Name: Craig
Default Drawbores for Breadboard Ends
Hello all, first time poster.
I am gearing up for a project and have a question about a technique that I want to use but have never done before. The project is a trestle dining table, made of red oak, and I'm planning to breadboard the ends. Every thing I am reading recommends drawboring these. As I understand the process, I would pre-drill the holes in the actual breadboard end, then mark its center on the tenon, then step in 1/16" closer to the should of the tenon and drill the hole in the tenon, and then elongate the hole to allow the peg to move laterally as the top contracts. My question is this, do you drive the peg through both side of the breadboard or is possible to to a "stopped drawbore" where the pin only goes through the top of the breadboard and the tenon.
Thanks,
Craig
craigwbryant is offline
post #2 of 6 (permalink) Old 10-22-2014, 12:09 PM
Semipro's Avatar
First Name: John_*
Craig
There are a number of utube video's on making and installing breadboards
Semipro is online now
post #3 of 6 (permalink) Old 10-22-2014, 12:14 PM
First Name: Phillip
I haven't done the technique, but there was an article about it in Fine Woodworking magazine a few issues ago, so I'm basically an expert.
Your description is correct (except you may want to go more like 1/32 instead of 1/16 offset). Also, there was no discussion of reshaping the size of the drilled hole. Instead, the article suggested that the pin be squarish and that one taper the pin slightly (without making the whole pin into a cylinder). This way, as you pound the pin, the pin top will eventually look like a squarish pin on the surface. The surface of the breadboard will conform to this shape. I don't see why you couldn't do a stopped draw bore. However, you would just have to be mindful of how much pin you would need until it feels snug (so you don't bottom out).
To change the world, change your mind.
phillipdanbury is offline
post #4 of 6 (permalink) Old 10-22-2014, 12:14 PM
Thanks,
Craig
try this thread for a lot of helpful information....
post #5 of 6 (permalink) Old 10-22-2014, 12:15 PM
oops...
forgot the link...
http://www.routerforums.com/router-b...n-project.html
post #6 of 6 (permalink) Old 10-23-2014, 10:55 PM Thread Starter
First Name: Craig
Thanks for the replies. I'll post pictures of the build once we get started in mid-December (have to get moved back to the east coast first!)
A jig to use for flattening the ends of logs billrouter1234 New Member Introductions 6 03-11-2013 09:28 PM
Are the ends on these window stools routed or miter returns?? RickDel Starting Off 12 07-10-2010 09:32 PM
Rounding off the ends of a stick tpyke Table-mounted Routing 5 03-03-2008 04:14 PM
