Am I diversified? - Router Forums
post #1 of 10 (permalink) Old 10-27-2014, 08:31 PM Thread Starter
Seldonman's Avatar
Default Am I diversified?
Probably every one on this side of the pond and on the correct upside of the world (just kidding) knows about Jim Cramer's Mad Money Television program. In this program he looks at your financial portfolio and tells you whether or not you are correctly diversified. Well, my question is not am I diversified, it is, am I level and square! You see, I purchased some nice black walnut scrap pieces and they are ruff on edges. One piece is 21 inches long and after planing I got it to where a level sits on the edge flush except for the last 2.5 inches in which I can insert a 0.005" (0.127mm) feeler gauge. I want to call this good because I am afraid of chasing this last bit down and making matters worse. What say you? Leave it alone or strive for perfection in everything you do?
I plan to use this wood to make a small box to hold K-Cups (for Keurig coffee makers) in so it will not be that large.
Thanks for any suggestions, advice, etc.
Jim
Seldonman is offline
post #2 of 10 (permalink) Old 10-27-2014, 09:13 PM
Harrison67's Avatar
First Name: Harrison
"What say you? Leave it alone or strive for perfection in everything you do?"
That's the way I've always looked at all things, in life.
Anyone, can be second-best.
Harrison
Harrison67 is offline
post #3 of 10 (permalink) Old 10-27-2014, 09:40 PM
First Name: Phillip
I think you're good. Don't want to take all the art from your woodwork, do you?
To change the world, change your mind.
phillipdanbury is offline
post #4 of 10 (permalink) Old 10-27-2014, 10:01 PM
It's called planer snipe. It's usually at both ends. If you measure it it will be exactly the distance the feed rollers and the planer head. Some planers have column locks to lock the head in place but it doesn't always eliminate it. A light finish cut may help. It seems to me I've heard of guys drilling and tapping the head casting on planers that didn't come with column locks.
post #5 of 10 (permalink) Old 10-28-2014, 06:15 AM
Country: South Africa
First Name: Paul
Jim
I would say your good to go and then once all pieces cut sand out any imperfections. I mean .1mm
PaulH is offline
post #6 of 10 (permalink) Old 10-28-2014, 09:30 AM
Hand plane the last pass?
Fraise is offline
post #7 of 10 (permalink) Old 10-28-2014, 10:53 AM
PhilBa's Avatar
First Name: phil
5 mils ain't much - couple of sheets of paper. To me, the real question is - will the unaided eye see the difference in the final product? For example, the eye can detect an amazingly small gap in a miter corner yet a shelf that has a much larger variation in thickness is not noticeable. Also, the amount of gap that is perceivable is dependent on the contrast and color of the materials. A gap shadow between two pieces of light colored maple will be much more visible than between two pieces of ebony.
PhilBa is offline
post #8 of 10 (permalink) Old 10-28-2014, 11:39 AM
rwl7532's Avatar
First Name: Ralph
The K-cups might complain?
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #9 of 10 (permalink) Old 10-28-2014, 12:50 PM
john60's Avatar
K cups can't complain a lot. They don't live that long
john60 is offline
post #10 of 10 (permalink) Old 10-28-2014, 10:14 PM Thread Starter
Seldonman's Avatar
Thanks everyone for the advice and you are right, K-cups don't live that long, at least around this house!
