recommend a new blade for my miter saw! - Router Forums
post #1 of 23 (permalink) Old 11-01-2014, 11:25 AM Thread Starter
First Name: jonathan
Default recommend a new blade for my miter saw!
hey guys,
I am about to purchase a new table saw in the next month or two but need to finish a few projects before then. I need to make some (semi-precise) cuts on some expensive ribbon mahogany (that i dont wanna screw up) for jewelry boxes. I might be able to get more precision and a better cut out of my sliding miter saw than my bandsaw but definately will need a new blade. Which brand (i was leaning toward Freud) and tooth count blade should i get? Right now i just have the stock bosch 40T blade that came with the saw which needs to be tossed anyway for a new one. Im sure ill have to sand some off either way. Thanks, jonathan
flitemedic13 is offline
post #2 of 23 (permalink) Old 11-01-2014, 11:40 AM
Forrest blades are really good. Most Freuds are good too. I have a glue line capable rip blade from Freud but it is heavy kerf. You will want a negative hook on a miter blade and 60 tooth minimum for good results I would say.
post #3 of 23 (permalink) Old 11-01-2014, 12:15 PM
Gaffboat's Avatar
First Name: Oliver
+1. It's also helpful to add a zero-clearance top to the table. You can make one easily by just attaching a piece of 1/4" mdf with double-sided tape.
Gaffboat is offline
post #4 of 23 (permalink) Old 11-01-2014, 12:48 PM
Rogerdodge's Avatar
First Name: Roger
Oliver , I think you will find the OP intends using his mitre saw for this project .....
Rog
Been at sea most of my life and still all at sea now.
Sometimes I sits and thinks and sometimes I just sits .
(M Twain)
Rogerdodge is offline
post #5 of 23 (permalink) Old 11-01-2014, 01:15 PM
First Name: Earl
Roger--i think that Oliver was referring to adding a temporary zero clearance on the miter saw. Tape a piece of 1/4" thick flat stock to the table (mdf is usually very flat), and another piece to the back fence. When i do it, my next step is to lay a piece of scrap 2" x 4" stock on the saw, make a cut to slice through the mdf. Doing this leaves a kerf that i can line up with my pencil mark, and cut with minimal visible tear-out on exit.
Works great.
earl
greenacres2 is offline
post #6 of 23 (permalink) Old 11-01-2014, 01:34 PM
Gaffboat's Avatar
First Name: Oliver
Works great.
earl
Yes, Earl, that's what I was suggesting. It reduces tear-out and makes it easier to line up your cuts. The attached shows what I did on my saw. The sandpaper helps me control the small pieces I've been cutting.
Gaffboat is offline
post #7 of 23 (permalink) Old 11-01-2014, 02:24 PM Thread Starter
Sweet idea, never thought of that ..and minimizes tear out, perfect!
post #8 of 23 (permalink) Old 11-01-2014, 03:08 PM
Rogerdodge's Avatar
First Name: Roger
Got it , thanks .
Rog
(M Twain)
post #9 of 23 (permalink) Old 11-02-2014, 05:35 AM
First Name: Gary
Jonathan, I have a freud blade on an old Rockwell (possibly the original) miter saw. The blade is at least 25 years old and now needs to be re-sharpened for the first time. Even being dull the blade still produces BABY BUT SMOOTH CUTS! Gary.
gmercer_48083 is online now
post #10 of 23 (permalink) Old 11-02-2014, 06:10 AM
Originally Posted by flitemedic13 View Post
hey guys,
can't go wrong w/ the Freud...
excellent bang for the buck...
don't forget that miter saws want negative hook angles...
Freud Tools
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 10:30 AM
Bosch 4100 EQUINOX400 Tools and Woodworking 23 09-16-2014 01:39 PM
Can Zero Tolerance Insert Be Routed Jerry Bowen Tools and Woodworking 13 11-11-2012 08:41 AM
For Sale: Ridgid 12" sliding miter saw - USED, works dovetail_65 Woodworking Classifieds 11 01-20-2011 11:28 PM
Changing a Miter Saw Blade sepulchre Tools and Woodworking 21 11-01-2010 09:35 AM
