Tip for sanding very small pieces - Router Forums
post #1 of 11 (permalink) Old 11-02-2014, 02:51 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Tip for sanding very small pieces
This is tip is probably obvious to all but I'll pass it on in case someone needs to sand a very small part that is difficult to hang onto and isn't sure how to go about it.
I had resawn some padauk to a thickness of about 1/32" on my bandsaw and needed to clean up the saw marks. I tried my usual method of laying sandpaper flat on the table and sanding by moving the work on the paper but I couldn't hang onto the thin pieces.
That's when I realized there had to be a better way.
My solution was to attach the piece to be sanded to a larger scrap with double-sided tape and use the scrap as a handle for sanding. It worked perfectly. Since the pieces were thin, I used a putty knife to peal it off the carrier scrap without breaking anything when I was done,.
Oh, and the reason I needed the thin material was for the bottom of a VTB (Very Tiny Box) I was making. I think I have reached my limits for tiny boxes with this one.
Gaffboat is online now
post #2 of 11 (permalink) Old 11-02-2014, 07:22 PM
Al B Thayer's Avatar
First Name: Al
Thanks for the tip. I also use D sided tape to hold pieces from slipping when drilling. I've used it to hold onto wood too small to grip when sanding too.
Thanks again
Al
The best things in life, aren't things.
Al B Thayer is offline
post #3 of 11 (permalink) Old 11-02-2014, 07:44 PM
Great tip, Oliver.
Sydney, Australia
jw2170 is offline
post #4 of 11 (permalink) Old 11-02-2014, 07:48 PM
First Name: Al
Double sided tape is great stuff
As I young machinist years ago I used it to tape thin phenolic to the table of a horizontal milling machine and would gang mill multiple slots with many slitting saws lined up on the arbor
Did it uncountable times,that material was under increadable cutting pressure and never had it move
Btw
Great work on the tiny boxes
What are they for?
al m is offline
post #5 of 11 (permalink) Old 11-02-2014, 08:00 PM
OK...now that I've seen it on your thumbnail, I'm really impressed!
DaninVan is offline
post #6 of 11 (permalink) Old 11-02-2014, 09:00 PM
Messy's Avatar
First Name: Carroll
Thank you Oliver.
Taking slobbery to new dimensions!
Messy...
Messy is offline
post #7 of 11 (permalink) Old 11-03-2014, 08:32 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
What!
No dovetails?
JK on VTB - EN = Just Kidding on Very Tiny Box - Extra Nice!
OPG3
Tweak everything!
OPG3 is offline
post #8 of 11 (permalink) Old 11-03-2014, 10:29 AM
First Name: thomas
I'll assume those very tiny boxes are to hold very tiny stuff, eh!
thomas1389 is offline
post #9 of 11 (permalink) Old 11-03-2014, 11:03 AM
First Name: Doug
Nice box. Do you use a respirator when you work with padauk? It gives me the sniffles and my eyes water when I sand it.
Doug A is offline
post #10 of 11 (permalink) Old 11-03-2014, 11:36 AM Thread Starter
Gaffboat's Avatar
First Name: Oliver
No respirator, just my usual dust mask. The padauk made fine dust and it seems like it gets on everything. I spent a lot of time vacuuming my table, the sandpaper, and myself after sanding.
How to make a jig to rout small pieces? ezachary Jigs and Fixtures 6 10-18-2011 10:32 PM
Tip Rotator Mark Site Help and Suggestions 4 03-10-2008 10:22 AM
routing small pieces zxxer12 General Routing 9 03-21-2005 03:40 PM
Hinges, locks on small pieces? Densa Jigs and Fixtures 4 01-27-2005 12:23 AM
1/2 lap on small pieces? Densa Jigs and Fixtures 4 01-26-2005 10:32 AM
