Darra James is in the house ! - Router Forums
post #1 of 20 (permalink) Old 11-16-2014, 05:22 PM Thread Starter
Nickp's Avatar
First Name: Nick
Default Darra James is in the house !
Today I picked up a Darra James Model 95, 12" table saw...for FREE...
If this is posted in the wrong place, please feel free to move it as I intend to continue updating it's restoration.
Thanks to all your advice to many posts regarding buying "old arn" I checked it over and have the following observations:
Both tilt and raise mechanisms are smooth and tight throughout the range...
No play on the arbor throughout the range...
Blade spins smooth with perfect balance and no runout...
All bearings and bushings are good and tight...
Top has only surface rust, and little of it...
All trunnions and innards mating surfaces are completely free of rust and no side to side play...
Motor spins freely, no high spots, no noises...
Tag says 2.25 or 2.45 hp (not clear til I clean it)
115/230 motor but not sure how wired as wires were cut...only two wires are connected in switch box, input wiring was replaced and looks like 14/2 Romex...
Recent sawdust is in the innards...
Cast aluminum wings...two on one side, one on the other...
Cast iron/steel insert...
Left tilt blade...
3/8 or 7/16 fence rail the full length with geared movement mechanism...no quick release unfortunately...plenty of micro adjustment...
No riving knife or blade guard...( my only dislike )
Cabinet is in great shape...no rust inside or out...
Did I mention FREE...?
I'm excited, needless to say but will not get to it for a while...and catch this, the serial number is my birthdate...karma, fate, or just plain coinkydink...?
Thanks for putting up with my excitement...
Nick
Nick
Nickp is online now
post #2 of 20 (permalink) Old 11-16-2014, 05:38 PM
Excellent find Nick. You didn't see a wiring diagram in the connection box? Either voltage only requires 2 wires and a ground. You might be able to find a video on you tube or a blog somewhere on how to test the motor leads to figure it out.
post #3 of 20 (permalink) Old 11-16-2014, 06:33 PM
RainMan 2.0's Avatar
Marcia ,Marcia ,Marcia !
J/k
Great find Nick , looks like Christmas came early. Mine came with a riving knife and I doubt I could even find it now lol
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 20 (permalink) Old 11-16-2014, 06:44 PM Thread Starter
Nickp's Avatar
First Name: Nick
No ground was connected...only black n white coming in from romex and red n black going to motor...the wires going to motor are obviously replacement and no box on motor...wires are taped together near motor...
I didn't look that carefully in the connection box but will check...thanks for the tip on researching...
Nick
Nick
Nickp is online now
post #5 of 20 (permalink) Old 11-16-2014, 06:46 PM Thread Starter
Nickp's Avatar
First Name: Nick
Thanks, Rick...LOL...
Nick
Nickp is online now
post #6 of 20 (permalink) Old 11-16-2014, 06:54 PM
Lately when I say " Marcia Marcia Marcia " the younger generation has no clue as to what I'm saying . I think the members here are old enough to know though lol
post #7 of 20 (permalink) Old 11-16-2014, 07:05 PM Thread Starter
Nickp's Avatar
First Name: Nick
So you won't mind if I call you Jan...? ROFLMAO...
Nick
Nickp is online now
post #8 of 20 (permalink) Old 11-16-2014, 07:38 PM
Hi Nick, just keep in mind that the reason the wires were cut were so that it could not be used...
I do that for any appliances that go out on the curb.
There could be a reason it was free.......
Sydney, Australia
jw2170 is offline
post #9 of 20 (permalink) Old 11-16-2014, 07:39 PM
Omg now that's funny! I'm ok with that
post #10 of 20 (permalink) Old 11-16-2014, 07:51 PM Thread Starter
Nickp's Avatar
First Name: Nick
Thank you, James...good point. I was told they were cut when it was moved and that it had been hard wired to circuit...I will check it out so thank you for the heads up.
It's my intent to check the motor before doing anything else...the county metal scrap yard is only a mile away... :-)
Nick
Nickp is online now
Free Doll House DXF pattern makecnc CNC Routing 36 11-25-2018 01:21 AM
Father's Day Cedar Log Bird House TRN_Diesel Show N' Tell 19 06-21-2014 08:38 PM
Beach House Signs chief5130 Show N' Tell 19 06-18-2013 09:06 AM
Here's James! Jack Wilson Lobby 13 05-28-2012 03:20 PM
House blew up! jd99 Lobby 4 10-02-2009 07:14 PM
