How Often Do You Check The Lower Thrust Bearing On You Band Saw - Router Forums
post #1 of 32 (permalink) Old 11-21-2014, 01:28 PM Thread Starter
First Name: Jerry
Default How Often Do You Check The Lower Thrust Bearing On You Band Saw
I was installing a new blade on my band saw this morning and discovered that the lower thrust bearing had gone gunny sack. The last time I installed a blade which was a couple of months ago the bearing was turning freely. It had quit turning and had a groove in it. It had gotten so hot that the grease had completely run out.
Fortunately my neighbor had a replacement. I order three new ones from Grizzly just now. I will be watching for this regularly in the future.
Maybe I'm the only one, but I doubt it, that is guilty of letting this situation happen with my saw. I'm wondering if others have had this experience or not. Also, do other people regularly check the bearing other than when changing blades?
Jerry B.
Jerry Bowen is offline
post #2 of 32 (permalink) Old 11-21-2014, 02:12 PM
pal
pal's Avatar
First Name: Harold
Jerry, I check the bearings every time before I switch the bandsaw on now as I have been caught a couple of times with knackered bearings.
Harold
Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning.
Albert Einstein
pal is offline
post #3 of 32 (permalink) Old 11-21-2014, 06:43 PM
First Name: Duane
Used to every time I changed blades... then I replaced it with a ceramic one.
Now... never!
Dmeadows is offline
post #4 of 32 (permalink) Old 11-22-2014, 10:53 AM
Garyk's Avatar
First Name: Gary
I have a habit of checking over EVERY power tool before I turn it on. I don't like surprises. That doesn't mean an "in depth" inspection of every part but those things that are easy to visually check. Several times each year I go "down in the bowels" and check all of the parts & pieces. It takes time but could save you money or avoid a bad accident some where along the way.
Garyk is offline
post #5 of 32 (permalink) Old 11-22-2014, 12:59 PM
Contributor of the Month
PhilBa's Avatar
First Name: phil
On my bandsaw, I check and adjust guides and thrust every time I change blades which is pretty frequent. I do a cursory check, including a quick tension check, every time I use it, though.
PhilBa is online now
post #6 of 32 (permalink) Old 11-22-2014, 01:01 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Good advice Phil, N
neville9999 is offline
post #7 of 32 (permalink) Old 11-22-2014, 01:58 PM
I have to laugh, when I changed my blade a couple of days ago, I found the same thing. I always keep an extra bearing on hand, have to order a new one now. I do a lot of resawing and they don't last long. Why don't they???
In my opinion they are using the bearing wrong or the wrong bearing. If the bearing was turned 90 degrees so it spun like a bearing is supposed to spin ,they would probably last forever. Here you have a blade pulling down on the side edge of the bearing on top turning the bearing that rubs on the bottom of the bearing causing friction heat and eventually freezing up the bearing and filing a groove from top to bottom. This bearing does not guide the blade only keeps it from being pushed back ,the guides are on the side.
Thats my opinion and I am sticking with it.
Herb Stoops is online now
post #8 of 32 (permalink) Old 11-22-2014, 03:23 PM Thread Starter
First Name: Jerry
Herb,
I'm not quite following you for sure. My saw, and I suspect that it is typical, is such that the bottom bearing, the one that just went bad on me is positioned parallel with the blade, and it's axle at 90 degrees to the edge of the blade. Hard to describe this, isn't it. The top thrust bearing is the one that is position at a 90 degree angle to the blade. The bearing on top is not as prone to get debri in it. The lower one is the one that is prone to getting the debri in it. The guy that helped me when I ordered replacements from Grizzly said that the lower bearing always seem to go first due to the debri.
As I said, I had always checked the bearing when changing blades but don't change them as often as some do. I, in my ignorance about such things did not have a spare on hand, but will in the future and will be checking all of the bearings on a regular and constant basis now after what I learned.
Jerry B.
post #9 of 32 (permalink) Old 11-24-2014, 05:20 PM
Hi Jerry,
Hmmmmm My cousins new last year 14" grizzly is the same as my Ridgid and the same as my Prior Craftsman 14" and 9" Delta ,just the opposite of yours.
Name:	IMG_1511 (800x600).jpg
Name:	IMG_1512 (800x600).jpg
Name:	IMG_1513 (800x600).jpg
Name:	IMG_1514 (800x600).jpg
Name:	IMG_1515 (800x600).jpg
post #10 of 32 (permalink) Old 11-24-2014, 07:53 PM
lenh's Avatar
First Name: Len
Hi Jerry,
Herb, without the pictures I would not have believed it. Why the thrust bearing would be "sidways" is beyond me. I know that on my Powermatic both bearings are the way they should be. After 10 years of pretty hard use, nary a problem. I don't find them to be full of the crud that your pictures show. (I use dust collection) Same is true of my little 10" Crapsman band saw - both bearings run in line with the blade.
Len
lenh is offline
Problem With Removing and Replacing Table On My Band Saw Jerry Bowen Tools and Woodworking 22 08-25-2013 06:18 AM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
PC lower router bearing sources, please XK140M New Member Introductions 8 09-24-2012 01:11 PM
top bearing kits? biloxi tom Router Bits - Types and Usage 3 09-12-2012 07:38 AM
