O.K. Need To Talk About Incra Jointery cuts.... - Router Forums
 1Likes
  • 1 Post By al m
post #1 of 10 (permalink) Old 11-26-2014, 05:20 AM Thread Starter
First Name: Jerry
Default O.K. Need To Talk About Incra Jointery cuts....
I have been using the Incra Jig for some time with good results except for ooe issiue that I have had to deal with that is not shown in the video demo.
The problem has been that after make cuts for through dovetail joints the fit has been tighter than I would like. In order to get a better fit I have simply widened the cuts slightly by moving the fence a few thousandths on both sides of the cuts.
This has not been worth talking about on the forum until recently when my friend Dick Willis installed an Incra LS 17 on his router and we began talking about the issue. So far we have pretty much come to the conclusion that the problem has to do with the bit being a tad undersized. The set of bits that I use are is one that I purchased from Incra and they are Whiteside bits.
I visited with Mark Mueller earlier about this and he agreed with me about the need to widen the cuts the way I had been doing it. Dick has just started using the jig and does not think that a person should have to widen the the cuts and while I agree with him, I still have to do it. Dick has a phone in to Mark about the matter but has not heard back from him as I write this.
We are wondering if other members that use the Incra jig have run into this problem or not.
My theory is that the Whiteside bits do not quite match the Incra templates . But it is only a theory on my part and is the reason for this thread.
I know that when making corner post joints that unless I widen the cuts the corner posts are very likely to be impossible to install without breaking them but the fit is fine when the cuts are widened about .010", .005" on each side of each cut.
I hope that some members will comment on this matter.
Jerry B.
Jerry Bowen is offline
post #2 of 10 (permalink) Old 11-26-2014, 05:44 AM
First Name: Al
I had this problem with my first few joints using bits out of a couple cheap sets of bits I had(master craft,craftsmen),then purchased a couple bits from lee valley and no problem
I do not have the white side/Incra set as I can not find it in Canada
al m is offline
post #3 of 10 (permalink) Old 11-26-2014, 05:52 AM Thread Starter
First Name: Jerry
Thanks Al,
Have by chance by miked those bits to see if the ones that work for you are wider than the other ones. If not, would you mind doing so and let us kniw what you find.
Jerry B.
post #4 of 10 (permalink) Old 11-26-2014, 05:58 AM
First Name: Al
Will check out the lee valley ones tonight,others are long gone
al m is offline
post #5 of 10 (permalink) Old 11-26-2014, 06:25 AM
First Name: Al
Had a few moments before going to work
First,what I did was a bit different as I made drawers for the kitchen with 5/8 maple
Had to make my own template but the relationship of cuts and cutter remains constant ,
The Lee valley bit ,tip to tip on a starret mic is.626, or plus .001
CabinCreek likes this.
al m is offline
post #6 of 10 (permalink) Old 11-26-2014, 06:37 AM
First Name: Al
I should add I do not believe a cut equal to cutter diameter is realistic
Spindle run out,collet run out, squareness of the spindle to the table,the way you hold your tongue etc are all going to influence the width of the cut and it will never get smaller.
Chances are the fact that you are running the cut a second time is as much a factor as moving over .005
al m is offline
post #7 of 10 (permalink) Old 11-26-2014, 06:47 AM
First Name: Duane
If it's dovetail joint fitting tight, lower the bit a hair. Highthen to tighten, lower to loosen. Should be that simple! Do the test cuts/setup first!
Box joints? Whole 'nuther issue. An undersized bit there will get you pretty tight joints.
I have good luck with my Whiteside bit ... not so much with an MLCS bit. The MLCS 3/8 bit I have is about 5-6 thousandths under size. That why I bought the Whiteside bit.. it is within +- 0.0015.
Dmeadows is offline
post #8 of 10 (permalink) Old 11-26-2014, 06:49 AM
First Name: Al
On second thought,my thinking is too greed to metal
I suppose it it possible,after a cut is taken,the wood could relieve stresses,or relax,thereby closing in on the cut in effect making it smaller that the cutter diameter
In that case a second pass at the same setting would open it back up
Just thinking out load
al m is offline
post #9 of 10 (permalink) Old 01-03-2015, 12:43 PM
PhilBa's Avatar
First Name: phil
I got an LS25 for xmas and and am shopping for router bits. Any follow up on this issue?
PhilBa is offline
post #10 of 10 (permalink) Old 01-04-2015, 12:34 PM
First Name: Don
As one of the posters said, either raise the bit or lower it for achieving a good fit, this is for dovetails only. This process and how to test for fit are described in the manual that has all of the templates. Moving the fence to do this will result in misery.
Duncanrouter is offline
I Want To Talk About The Incra Jig Jerry Bowen Tools and Woodworking 6 02-23-2014 10:28 AM
Cross Cuts Differ From Rip Cuts... Jerry Bowen Tools and Woodworking 9 07-15-2013 11:27 AM
Discussion About The Incra Dovetail Jig Jerry Bowen Tools and Woodworking 11 07-01-2012 04:13 PM
Incra Dovetails - cuts going with the bit Steve-H Table-mounted Routing 8 02-01-2012 10:18 AM
Router Lifts: Incra SWHD vs. Incra PRL-V2 Gato9 General Routing 0 09-23-2011 08:14 AM
