One Lie Nielsen is not enough - Router Forums
post #1 of 17 (permalink) Old 11-28-2014, 08:23 AM Thread Starter
xplorx4's Avatar
First Name: Jerry
Default One Lie Nielsen is not enough
Well broke for the #4 smoothing plane and am very pleased with it. But I must say that's all for now folks, there are some other needs in the shop to be met first.
Lamentations 3:22-23
xplorx4 is offline
post #2 of 17 (permalink) Old 11-28-2014, 09:32 AM
IC31's Avatar
First Name: Dave W
Ah yes, priorities. Nice pair of planes
They generally come to our local show and 2-3 years ago they had some overstock on their small block planes at a very nice reduced price ......... That plane is carefully wrapped and stored in its box between uses.
I do have to say that it did need a good honing to work well and that surprised me.
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is offline
post #3 of 17 (permalink) Old 11-28-2014, 01:21 PM
Phil P's Avatar
First Name: Phil
Well, Dave, after you've used it a bit it will need a lot more honing, so........
Phil P is offline
post #4 of 17 (permalink) Old 11-28-2014, 02:32 PM
IC31's Avatar
First Name: Dave W
Phil - I was just surprised that out of the box that it wasn't better. It is now after a session with a very fine stone and a leather strop. As far as using it - it does as often as needed and unfortunately that could be more. But that's another story for another day
Dave W
IC31 is offline
post #5 of 17 (permalink) Old 11-28-2014, 04:43 PM
TwoSkies57's Avatar
Jerry...
Nearly as impressive as your body of work lately...
Skipper the Penguin
TwoSkies57 is offline
post #6 of 17 (permalink) Old 11-28-2014, 05:00 PM
correct....
BTW..
nice score on that #4....
post #7 of 17 (permalink) Old 11-28-2014, 05:04 PM
Nice present to self, Jerry.
Sydney, Australia
jw2170 is offline
post #8 of 17 (permalink) Old 11-28-2014, 06:53 PM
old55's Avatar
First Name: Ross
Nice one Jerry.
Ross,
old55 is offline
post #9 of 17 (permalink) Old 11-29-2014, 09:56 AM
It is amazing the craftsmanship of those planes. It always strikes me that any good plane needs a tuneup before use. I guess the metal changes slightly after manufacturing. I just bought a small digital measuring device for setting blade depth. Just can't see well enough anymore to set the depth by eye. It was only $20.
DesertRatTom is online now
post #10 of 17 (permalink) Old 11-29-2014, 01:23 PM
Phil P's Avatar
First Name: Phil
Hi Tom
All iron castings move to an extent - partly the result of stresses being released by the machining process. L-N, Clifton and Veritas planes, though, seem to be well destressed and within tight tolerances as made - planes such as Wood River aren't as good and require a little work. A lot of the cheaper stuff is really dreadful. Nice things about the quality planes includes lack of blade chatter, edge-holding and sharpness of the iron and lack of slop in the adjuster mechanism but it's maybe worth remembering that any of the premium planes around today are better than what you could get 100 years ago
I don't understand why you'd need it when you can just do a test cut and adjust on a scrap. The transparency of the shaving is a pretty good indicator of setting I find.
Regards
Phil
Phil P is offline
Lie Nielsen block plane xplorx4 Tools and Woodworking 13 11-11-2014 07:21 AM
LIE Seng-Tjhen cstlie New Member Introductions 1 07-06-2009 04:24 AM
Lie Nielsen rmaxa Shows & Events 0 06-26-2009 08:07 PM
For Sale: #4 Lie Nielsen Plane arkwood Woodworking Classifieds 5 01-13-2007 09:35 PM
