Dowel jointing at 45 degrees. - Router Forums
post #1 of 38 (permalink) Old 12-02-2014, 06:49 PM Thread Starter
Country: Argentina
First Name: Pablo
Default Dowel jointing at 45 degrees.
Hi, I need to be able to repeatedly and precisely make holes for dowels to joint 2 pieces of wood in the way the picture shows:
I didn't come out with a method for this yet, I thought of building some kind of structure with predrilled holes, then push the piece of wood there and drill with some kind of stop.. but.. not sure.
Any ideas?, do I need to have a drill bank for this?, I don't, but if required I could get one I guess.
(btw, if you think of a better way to joint this, let me know!, for the moment is only glued, the structure is only used for a picture frame, so is not required to be strong, but, the stronger the better I guess.)
Artemix is offline
post #2 of 38 (permalink) Old 12-02-2014, 08:53 PM
jump to the head of the class...
Dowl-It 2500 Jig | Doweling Jigs
splines or biscuits would be simpler, more accurate and faster...
change the type of miter...
http://www.table-saw-guide.com/image...bbet-joint.jpg
post #3 of 38 (permalink) Old 12-02-2014, 08:55 PM
First Name: Earl
Nothing coming to mind on the doweling, but for other methods:
Splines are nice
Bowtie inlay at each corner
Pocket holes (only on frames i'm not gifting--personal use only). Actually, with pocket holes, i don't even glue the corners, and i can whip up a frame pretty quickly.
earl
greenacres2 is offline
post #4 of 38 (permalink) Old 12-02-2014, 09:54 PM
Lets hear it for Pocket Holes.............I'm listening...........Don't hear much........?????
I love pocket holes for face frames and they are fast and strong, no glue either. Don't know how they would work on mitered corners,will have to try that.
Herb Stoops is online now
post #5 of 38 (permalink) Old 12-02-2014, 09:58 PM
Still listening.
post #6 of 38 (permalink) Old 12-02-2014, 10:10 PM
Sorry, I'm with Stick about splines or biscuits. Fast and easy. Can be done on a TS, router table, or with biscuit joiner. Done properly can eliminate alignment problems which can be a problem with dowels or screws.
post #7 of 38 (permalink) Old 12-02-2014, 10:12 PM
Originally Posted by Herb Stoops View Post
Still listening.
I use them when is it's the best for the application..
gorilla strong too...
a biscuit and a pocket screw would be fast, accurate, strong, no muss, no fuss KISS/MISS....
post #8 of 38 (permalink) Old 12-03-2014, 05:22 AM
First Name: Earl
Still listening.
Sorry, i was snoring...the only noise you'd have heard.
They work very well, just have to hold back from the outer edge a bit. I've done a handful of mitered frames that way, no glue, no problems. Just cut an accurate corner, align correctly, clamp really tight, screw, done.
earl
post #9 of 38 (permalink) Old 12-03-2014, 06:10 AM
I use the "Ozzie Jig" for dowels and it works great for mitre corners.
Not sure if it is still available...
http://youtu.be/APVF8u5vx3c
Sydney, Australia
jw2170 is offline
post #10 of 38 (permalink) Old 12-03-2014, 06:14 AM
Country: South Africa
First Name: Denis
Pablo
I like to quote American author, Jim Tolpin:
"Dowel joints are foul joints." A dowel joint is difficult to drill accurately and has very little face-grain to face-grain gluing area and is destined to fail over time. I agree with the other replies you got. I would use a biscuit (plate) joint or pocket hole screws.
Denis Lock - "Routing with Denis"
denis lock is offline
Hole too Large - Dowel too Small 57759 Tools and Woodworking 19 02-02-2020 10:41 AM
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 11:19 AM
Changed My Mind About the Dowel Max Jerry Bowen Tools and Woodworking 7 02-04-2014 12:26 PM
ACME Super Dowel Cannon Gaffboat Show N' Tell 24 08-08-2012 08:10 PM
Temperatures AxlMyk Lobby 2 01-30-2009 02:49 PM
