Muti -Tool - Router Forums
post #1 of 32 (permalink) Old 12-16-2014, 05:04 PM Thread Starter
Default Muti -Tool
OK you guys, I am starting to think seriously about getting a Multi-Tool.
What do you Multi-tool users use? I am not into big projects anymore just small stuff probably sanding and cutting in odd shaped corners etc.
there must be some that woodworkers really like.
No Festools please,
Herb Stoops is offline
post #2 of 32 (permalink) Old 12-16-2014, 05:19 PM
First Name: Duane
Herb, my FIL, my best friend and I, all have the $15 Harbor Freight one. One of HF's little gems as far as I'm concerned! I was really surprised just how well it works.
My FIL has bought at least a couple of them, not because they fail, but because his kids see how well the work and want them also!
Oh, I'd NEVER recommend Fe$tool, by the way.. too rich for my blood!
Dmeadows is offline
post #3 of 32 (permalink) Old 12-16-2014, 05:23 PM
I bought the ROK kit, Herb. I have nothing but good things to say about it.
Been trouble free so far.
https://www.canadianwoodworking.com/...ng-multi-tools
Seems like everybody has the 'kit' on sale right now.
(Xmas prezzy for dad? ...or Mom, in Angie's case!)
DaninVan is online now
post #4 of 32 (permalink) Old 12-16-2014, 05:47 PM
RainMan 2.0's Avatar
Originally Posted by Herb Stoops View Post
No Festools please,
Ok ,I never insulate
RainMan 2.0 is offline
post #5 of 32 (permalink) Old 12-16-2014, 06:03 PM
I bought the Canadian Tire one and it has been surprisingly good. That wouldn't normally be of help to you but my brother thought it might be the same tool Harbor Freiht sells for around $30 -40. If I were to replace it with a better one I might go Bosch just because of their reputation.
post #6 of 32 (permalink) Old 12-16-2014, 06:27 PM
MT Stringer's Avatar
I used mine to cut the base molding where I was installing the end cabinet for ourr Buffet and the wet bar I built for our friends. made perfect cuts. Just a tad of caulk and it looked like original construction.
The little triangular tool helps sand in tight places.
MT Stringer is offline
post #7 of 32 (permalink) Old 12-16-2014, 06:34 PM
No Festools please,
I have the Fien...
got Bosch too...
nothing like the Fien and Bosch holds their own against it...
both of them are top rated..
once you have one the get'er done list will grow and grow and grow...
it's one of the tools....
where have you been all my life...
even took my cast off w/ it...
don't waste your money on the Rockwell, HF, PC or Dremel...
got experience with them too...
The Fein blades are very good but there is no point in shelling out big bucks when as good or maybe better can be had for a lot less...
do not waste your money on Asian blade...
stick w/ USA, German, Swiss and Austria made blades...
post #8 of 32 (permalink) Old 12-16-2014, 06:36 PM
First Name: Al
Have the ctc like Chuck,cheap tool that has got me out of a few jams,don't use often but for those once in a while nothe else will do it jobs I am happy to have it
al m is offline
post #9 of 32 (permalink) Old 12-16-2014, 06:49 PM
Just for the sake of information, here's the current ROK price at Summit Tools (Canada)
post #10 of 32 (permalink) Old 12-16-2014, 10:03 PM Thread Starter
Thanks guys ,I see where this is going to be a tough decision.
And Rick, nothing against Festool, they are the Cadillacs of tools, I am Ford/Dodge guy.
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 03:33 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 10:12 PM
Peak HP dgcutter General Routing 22 01-10-2013 08:23 PM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-07-2012 11:17 PM
proper tool use locoboy Lobby 0 04-01-2009 02:45 PM
