My Delta 9 inch Table Saw - Router Forums
 1Likes
post #1 of 12 (permalink) Old 12-17-2014, 06:59 PM Thread Starter
First Name: lee
Default My Delta 9 inch Table Saw
I finally have my Delta 9 inch table saw together. I bought the saw without a fence for $70.00. I added a Delta T2 fence by drilling 2 holes to make the fence fit. I fired the saw up and it started vibrating and hopping on my raised wood shop floor. I noticed the motor pulley was not running true. It was a little off. So I replaced the motor pulley and the arbor pulley with machined pulleys and a link belt. The saw now is very smooth.
Blades are hard to find but they make them. I also bought a forty tooth Freud blade. I hope it will be a good one. I like this little saw. I don’t have a lot of room in my shop so I may have to move it. I added 2 handles to the TS base so my saw can be lifted easily without cutting into your hands.
PS
I forgot I also had to reposition the rear fence’s foot for the back track as my top is only 22 inches wide instead of the standard 27 inch top.
coxhaus is offline
post #2 of 12 (permalink) Old 12-17-2014, 07:29 PM
I have heard that the link belts make a big difference.
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 12-17-2014, 08:41 PM
RainMan 2.0's Avatar
Wow that belts a first , never seen one before . I didn't even know they made a 9" table saw?
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 12 (permalink) Old 12-17-2014, 08:48 PM
You can buy the links at Lee Valley Rick and you link them together to make a belt the length you need it.
That looks like a good fence Lee. Most saws will saw okay with the major difference being how much power but what makes them a precision cutting tool is a good fence and at least a decent blade
post #5 of 12 (permalink) Old 12-17-2014, 10:39 PM Thread Starter
First Name: lee
I have also heard the fence makes a difference. The guy I bought the table saw from was a real wood worker and had a Biesemeyer fence on it. He wanted the fence for his new table saw. He said if I bought a good fence the saw would be accurate. I priced the Biesemeyer fence and they were too expensive for me. I found on eBay they had the Delta T2 fence for $160.00 so it sounded good to me and I bought it. The saw has a Rockwell 1 Ĺ hp motor which is about as big as you get on a contractor saw so hopefully I have that covered too. I hope this saw will serve me well. I have a few projects coming up and time will tell.
Blinky likes this.
coxhaus is offline
post #6 of 12 (permalink) Old 12-18-2014, 07:57 AM
waynecochran's Avatar
First Name: Wayne
I put machined pulleys and a link belt on my jet contractor saw and my old import band saw and both now run smoother and quieter.
waynecochran is offline
post #7 of 12 (permalink) Old 12-18-2014, 08:59 AM
Lee your biggest issues will be the lack of selection in 9" blades and the short out feed. I bought an old Rockwell off a friend for a second saw and added a melamine table on the side and when I did I extended it behind the saw 8-9 inches. I braced the extension to the saws legs with light angle iron which would still leave it mobile in your case. So the short out feed is a solvable problem which you may want to consider. I find the saw easier to use and safer with it there.
I had considered one other option too and that was adding a 24-36" extension that attached to the saw with hinges and with fold up legs. If your motor sticks out the back that will make it harder but you still might be able to cut a section out of the extension. I have a 3' or so extension on my big saw and I would not want to be without it now.
post #8 of 12 (permalink) Old 12-18-2014, 10:06 AM
Nice job on that saw. A friend had one of those he'd used for a very long time. The fence and blade are surely the key, so long as the blade is square to the miter slots. I also suggest you build an outfeed table. It is so much safer. As to blades, when you find them, make sure you have at least 2 of the ones you need most so you have a backup while one is sharpened. Beside that, you may find that eventually, they are no longer available new. Really good job on reconditioning and adapting that saw.
post #9 of 12 (permalink) Old 12-18-2014, 11:08 AM
MikeMa's Avatar
Well done. I put the T-2 Fence on my craftsman table saw a number of years ago, and have been very happy with it.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #10 of 12 (permalink) Old 12-18-2014, 11:37 AM
I get link belts at harbor freight and they are cheaper,have them on all my machines,they run quieter great invention.
Herb Stoops is online now
New to forum. archie2401 New Member Introductions 13 12-08-2014 07:21 AM
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
10 inch table saw max RPM locoboy Tools and Woodworking 10 08-07-2011 12:02 AM
Wanted: WTB..Table Saw Fence...Delta T-2 or Other deck99 Woodworking Classifieds 3 08-25-2007 10:21 PM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
