Groove Cutting Suggestions - Router Forums
post #1 of 13 (permalink) Old 12-18-2014, 04:13 PM Thread Starter
Contributor of the Month
Default Groove Cutting Suggestions
I have a piece of soft maple, 5/4" X 2 7/8" X 72". I need to cut a groove, 1/4" wide by X 1/4" deep centered in the 2 7/8" side, along its entire length. Would you cut it on the router table with a straight cutting bit or use a dado blade in the table saw? I have a router 1/4" slot cutting bit but it's not tall enough to use.
JIMMIEM is offline
post #2 of 13 (permalink) Old 12-18-2014, 05:04 PM
MT Stringer's Avatar
Unless I am missing something, I don't see any difference from using the router table to cut the grooves into the sides of drawer stock.
I would use a 1/4 inch straight bit and make two passes (face down) cutting 1/8th inch on the first pass and then finish at the 1/4 inch depth.
Practice on scrap to get the cut centered before you make the actual cut.
Hope this helps.
Note: I attached a pic. Is this what you want to do?
Name:	Quarter inch groove..jpg
MT Stringer is offline
post #3 of 13 (permalink) Old 12-18-2014, 06:39 PM
I would use the table saw probably with just the regular blade. If you start with the blade near dead center, make a pass, and then spin the board around 180* and make another pass then the resulting groove will be dead center. Just move the fence gradually farther from the blade and do the same 2 passes until you get the width you want. Remember that each fence adjustment is x 2.
post #4 of 13 (permalink) Old 12-18-2014, 07:19 PM Thread Starter
You got it! Thank You. Yes, same idea as the drawer side....just longer.
JIMMIEM is offline
post #5 of 13 (permalink) Old 12-18-2014, 07:56 PM
You might need to set up a temporary outfeed table...or grab a helper.
post #6 of 13 (permalink) Old 12-19-2014, 04:56 AM
I would do it as Charles suggests w/ a FTG blade...
post #7 of 13 (permalink) Old 12-19-2014, 08:06 AM
For grooves like that, I prefer the table saw. A dado blade setup gives a really nice flat bottom groove, but I'd definitely be very careful calculating the distance from blade to fence. Very easy to get it off center.
If you choose to use what Chuck and Stick suggested, consider a Freud blade with every 4th tooth flat to help clean out the bottom of the groove nice and flat. http://www.amazon.com/Freud-LM75R010...+ripping+blade
post #8 of 13 (permalink) Old 12-19-2014, 08:08 AM
First Name: Richard
I agree with Charles and Stick. Don't make it harder than necessary.
Shop guy is offline
post #9 of 13 (permalink) Old 12-19-2014, 08:16 AM
john60's Avatar
You have a wide enough piece that with a good edge guide on your router you could do this freehand in two passes.
john60 is offline
post #10 of 13 (permalink) Old 12-19-2014, 08:28 AM
Phil P's Avatar
First Name: Phil
Hi Jim
On a plunge router with a side fence a job like that is a doddle on an item as big as a drawer side. 1/4in x 1/4in I'd probably do it a single pass - depends really on whether or not the vacuum can pull the swarf out of the groove - if it couldn't the I'd be doing two passes
On a router table I have slotting cutters which will do that in a single pass, but as an installer I don't always have a router table to hand
Either way, like you, I'd make a practice cut first
Regards
Phil
Phil P is offline
cutting a stopped groove knnthrawson General Routing 21 12-21-2013 10:31 PM
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 10:15 AM
Cutting groove in cutting board Ken Brown Jigs and Fixtures 7 01-06-2010 09:57 AM
routing the groove on a cutting board Grandadpjp General Routing 3 01-05-2010 01:15 AM
Cutting a curved groove rsmtg New Member Introductions 3 09-25-2008 10:56 PM
