Is this fixable?. - Router Forums
post #1 of 23 (permalink) Old 12-21-2014, 07:04 PM Thread Starter
Country: Argentina
First Name: Pablo
Default Is this fixable?.
Hello guys, I'm having an issue with my saw currently, and I want to know if this is calibrate-able or if my saw is beyond fixing.
I'm making a crosscut sled for a 45 degrees tilt blade, basically, it's the same as the regular one, just the blade is inclined at 45 degrees, what happens is the following:
- I measure perfectly 90 degrees from the blade to the fence, with the blade at 90 degrees.
- I incline the blade 45 degrees, measure again, I got a different angle, and a very noticeably different one, I'd say, 85 degrees.
I'm not sure I can fix this, but you let me know what you think.
Thanks.
Artemix is offline
post #2 of 23 (permalink) Old 12-21-2014, 07:15 PM
not seeing what happened...
85°???
what are using to measure and where from???
post #3 of 23 (permalink) Old 12-21-2014, 07:27 PM Thread Starter
Country: Argentina
First Name: Pablo
I'm using a square.
Artemix is offline
post #4 of 23 (permalink) Old 12-21-2014, 07:30 PM
where did the 85° come from???
post #5 of 23 (permalink) Old 12-21-2014, 07:41 PM
Nickp's Avatar
First Name: Nick
Have you checked the screws on trunnion brackets for tight...?
Power off and unplugged, lower halfway when tilted and manhandle the parts from underneath...with the lock on and with it off
Picture from straight above would be helpful...put your square in the picture just like you have measured...
Nick
Nickp is offline
post #6 of 23 (permalink) Old 12-21-2014, 07:43 PM
Hi Pablo, are you measuring from the table or the sled?
that could make a huge difference...
Sydney, Australia
jw2170 is offline
post #7 of 23 (permalink) Old 12-21-2014, 08:00 PM Thread Starter
Country: Argentina
First Name: Pablo
I'm measuring from the sled fence.
I will take some pictures if you need so, maybe in my mind it sounded easy to explain, perhaps it's not.
Basically, imagine this:
- you are building a crosscut sled, you finish building it, all your cuts are perfect 90 degrees.
- now you tilt the blade, and suddenly your 90 degrees are gone.
Is that clearer?.
Artemix is offline
post #8 of 23 (permalink) Old 12-21-2014, 08:11 PM
the blade is rotating left to right on it's center axis???
is this your new table saw???
post #9 of 23 (permalink) Old 12-21-2014, 08:31 PM Thread Starter
Country: Argentina
First Name: Pablo
The blade tilts in this way:
http://www.altendorf.de/uploads/pics...3_Bild3_01.jpg
Artemix is offline
post #10 of 23 (permalink) Old 12-21-2014, 08:35 PM
how so???
