belt sanders sanding frames - Router Forums
post #1 of 3 (permalink) Old 12-21-2014, 07:05 PM Thread Starter
First Name: Peter
Default belt sanders sanding frames
Hi
Has anyone used the sanding frame for the Bosch 3 inch belt sander? If so, how did it go? If you have used the Festool 3 inch belt sander with sanding frame also, how does it compare with the bosch sanding frame?
Thanking you
Peteroo
Peteroo is offline
post #2 of 3 (permalink) Old 12-21-2014, 07:24 PM
Originally Posted by Peteroo View Post
Hi
Has anyone used the sanding frame for the Bosch 3 inch belt sander? If so, how did it go? If you have used the Festool 3 inch belt sander with sanding frame also, how does it compare with the Bosch sanding frame?
Thanking you
Peteroo
are you referring to the frame that holds the sander upside down for use...
if so that system was discontinued a very long time ago here in the USA...
I used one for awhile till it was stolen.. it had it's merits but it can't hold a candle to a stationary tool..
post #3 of 3 (permalink) Old 12-22-2014, 02:10 PM
Phil P's Avatar
First Name: Phil
Hi Peter
Sadly I have used neither. 3in belt sanders I find a bit slow..... But I have a Makita 9404 4in belt sander and I used to have an Elu MHB157 3in belt sander inthe past, so I at least know what you are referring to. It's something like this. The Makita one is really basic compared to the old Elu one, but it does the job. I have to say that most of the time I use a belt sander flat out without the sanding frame/shoe in place, but I have to admit that you have to be very careful not to sand through on thin veneers - the sander has to be kept moving from side to side all the time and never allowed to dwell. The one time I'll use the frame, though, is when I'm sanding out a veneered door or panel,. Sort of insurance, I suppose
Regards
Phil
Phil P is offline
Sanding BernieW Woodturning and Lathes 9 12-29-2011 07:01 PM
Sander 9924DB/9401/9901 belt sanders allthunbs Makita Manuals 0 03-07-2011 04:42 AM
How To Finish Sanding Moulding Of Door? Gaia The Finishing Touch 8 01-11-2011 02:32 PM
Hand held belt sanders RJM60 Tools and Woodworking 7 10-17-2010 05:31 PM
