Seeking a chuck for small drill bits - Router Forums
post #1 of 23 (permalink) Old 12-26-2014, 12:31 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Default Seeking a chuck for small drill bits
I'm looking for a chuck for small, less than 1/8" bits, the end shaft of which can be accepted in the standard chuck on a drill press and small hand drills. I've seen these in years past but have not been able to locate a source for one. Perhaps a firm that supplies tools for jewelers?
Also open to alternative suggestions for drilling very small holes.
Thanks in advance.
Cheers
Jon
Jon
JFPNCM is online now
post #2 of 23 (permalink) Old 12-26-2014, 12:40 PM
Outstanding company to deal with...
http://www.travers.com/Search/Search...DRILL%20CHUCKS
post #3 of 23 (permalink) Old 12-26-2014, 12:49 PM
Each time you extend the reach with an extension or chucking a chuck into another chuck you risk losing some or your concentricity so you may be defeating your purpose. You can get chucks with smaller capacities for 3/8 drills that will replace the chuck on it. I was looking on eBay a couple of years ago for a couple of chucks to replace the broken ones on the drills my son-in-law gave me from his shop and found out you can spend $1000 on a drill chuck if you want to.
post #4 of 23 (permalink) Old 12-26-2014, 01:13 PM
Thanks in advance.
Cheers
Jon
change the chuck out to zero to what ever....
but speed and torque will be issues...
for really small bits to power drill look to a mini bench top DP....
Best Small Benchtop Drills - Mini Tabletop Drill Presses
Dremel work stand...
http://www.amazon.com/gp/product/B00...SIN=B00068P48O
post #5 of 23 (permalink) Old 12-26-2014, 04:20 PM
Here's a couple of sources of info on drilling with small capacity chucks...
Stick had posted some links earlier on a different thread.
http://www.use-enco.com/CGI/INDRVSHh...om/CGI/INDRVSH
Drill Presses & Chucks
DaninVan is offline
post #6 of 23 (permalink) Old 12-26-2014, 04:22 PM
DaninVan is offline
post #7 of 23 (permalink) Old 12-26-2014, 04:23 PM
couldn't fi8nd it...
post #8 of 23 (permalink) Old 12-26-2014, 04:34 PM
DaninVan is offline
post #9 of 23 (permalink) Old 12-26-2014, 04:37 PM
looked in all the wrong places...
post #10 of 23 (permalink) Old 12-26-2014, 07:29 PM
Nickp's Avatar
First Name: Nick
Depending on what you're drilling, maybe a "pin vise" might be appropriate...I've used it on soft metal like aluminum, brass, "pig iron" and wood, etc...
Nick
Nick
Nickp is offline
Benchtop Drill Press Modification JimS Tools and Woodworking 23 07-19-2018 12:51 PM
Router bit testing Mike Router Bits - Types and Usage 21 12-17-2014 09:42 AM
Bosch Cobalt Drill Bits jschaben The Bargain Bin 1 09-27-2012 03:16 AM
Bits stick in chuck StuckChuck General Routing 12 12-29-2010 04:09 PM
Bradpoint drill bits g-man Tools and Woodworking 2 11-27-2005 04:11 AM
