iVac Switchbox Model SB-NA - Warning - Router Forums
post #1 of 5 (permalink) Old 01-02-2015, 01:55 PM Thread Starter
PhilBa's Avatar
First Name: phil
Default iVac Switchbox Model SB-NA - Warning
I have yet to use this product but was struck by their labeling when I opened it up. The first picture shows the outside of the box clearly stating 15A current capacity. The second picture shows the inside where the device itself says 12A and the sticker says 9A. No where on the outside does it say 9 (or even 12) amps. While I get that ratings can change, having 3 different ratings is disturbing. I think it’s really bad when the outside says one thing but the inside says another. The additional sticker further down-rating the device pretty much left me speechless. I can only assume the reason is due to a rash of returns and damaged devices that failed when used within the limits of their specs. Probably they did in process “value engineering” and cheapened it a bit too much. What bothers me is the sticker is on the inside, not the outside.
Now, this was on sale for a “good” price ($44) at Woodcraft so they are probably flushing the crappy inventory. I think I’m going to use it because the vac that I intend to use it with isn’t that powerful. However, I probably won’t buy another product from iVAC due to their lack of ability to honestly label their products. Woodcraft gets a little bit of hit in that they participated in what is basically a fraud though they may not have actually opened one up.
Name:	ivac 20150102_112224.jpg
Name:	ivac 20150102_112241.jpg
PhilBa is online now
post #2 of 5 (permalink) Old 01-03-2015, 09:58 AM
I was looking at one of these, but the bad reviews stopped me. Glad I didn't get one.
post #3 of 5 (permalink) Old 01-03-2015, 11:40 AM
I think you are right, Phil, it being a CYA after thought, the way the sticker is applied to the unit over the face of the outlets.
The same thing happened to me from another store I buy from with speed controllers, They had 12a. And 15a. so I bought the 15a. and after I had them in use I happened to notice they were marked 12a. so I dug around in the trash and found the box,sure enough they were marked 15a. on the box. I am using them anyway,they seem to be holding up OK.
Maybe the Import AMPS are larger than the USA amps. LOL (are 220 amps twice as large as 110 amps?)
Thanks for the warning,Others need to be aware of this.
Herb Stoops is offline
post #4 of 5 (permalink) Old 01-03-2015, 12:19 PM Thread Starter
PhilBa's Avatar
First Name: phil
Or maybe Canadian Amps where the exchange rate .75. Lol.
post #5 of 5 (permalink) Old 01-03-2015, 12:46 PM
Originally Posted by philba View Post
or maybe canadian amps where the exchange rate .75. Lol.
hahahahahahahaha
Model Railroad building modelling software kp91 Lobby 4 08-19-2013 11:54 AM
Which Model PC router TKirk General Routing 3 07-09-2013 04:21 PM
new model carvewright model c lenny760879 CNC Routing 9 05-25-2012 01:04 PM
Ship Model densships Show N' Tell 19 05-10-2008 05:58 PM
model 315 17351 = model 735-2 headclansman General Routing 2 04-28-2008 02:13 AM
